steering strangeness part 2
Discussion in '1st Gen. Tacomas (1995-2004)' started by coehorn1, Oct 14, 2010.
  1. Oct 14, 2010 at 11:55 AM
    coehorn1
    coehorn1 [OP] Well-Known Member
    '03 4x4 2.7I4 5sp "beast"
    A short while ago, I bought a rebuilt steering rack for my '03 and had a dealer install it. That was an adventure in itself.
    A few days ago, I start the truck and I hear the whine of a power steering pump that needs fluid. I pick up some that matches the requirements in the owners manual and top off this reservoir. Since then, it is needing power steering fluid daily.
    I crawled under the truck and it appears that the passenger side rubber bellows on the steering rack has fluid dripping from it. Is this a repair that can be made to this steering rack or do I need a new steering rack?
    Any advice really appreciated.
  2. Oct 22, 2010 at 7:16 AM
    coehorn1
    Found a local mechanic that was highly favored and finally got the time to take it in. He said that both main outer seals had failed in the rebuilt rank and pinion mechanism. He suggested replacing the unit.
    Cost for first time parts + labor = $450
    Cost for second time parts + labor = $700
    Buying a rebuilt starter or alternator is no big deal but a rebuilt pressure plate (many years ago) and now a rebuilt rack and pinion have cost me dearly.
    Something to think about.
  3. Oct 22, 2010 at 7:31 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    iirc, my dealer wanted almost a grand for a new rack. ..but it also came with a lifetime warranty.
  4. Oct 22, 2010 at 6:14 PM
    kawiman6565
    kawiman6565 Member
    Derek
    Southern NH
    95 Tacoma
    3 inch rough country lift, 31" Dakotas, Hella lights, alloy Toyota wheels, on board aircompressor
    I just purchased a rebuilt power steering pump for my 95 taco and put it in. I bleed the system and topped off the fluid and it is whining. does anyone know what the problem with this might be?
  5. Oct 23, 2010 at 10:03 AM
    pebbles
    pebbles Active Member
    2000 2WD Tacoma w/3" Lift
    How does whining noise sound,can someone post a video we can listen to ?
  6. Oct 23, 2010 at 10:27 AM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    I brought my truck into the dealership to have the power steering fluid flushed and they couldn't do it because there was fluid leaking into the right boot...Quote for a steering rack and labour $664.00 + tax...Power steering flush $89.95 and a wheel alignment recomended...
  7. Oct 23, 2010 at 10:54 AM
    fidencio74
    fidencio74 Well-Known Member
    Fidencio
    Escondido, CA.
    2018 TRD Sport 4x4
    Stock for now
    I just changed my Power Steering pump, I got it from Kragen and the pump started making all kind of noises, I paid for it $116 + tax. I took it back and got one from the dealer for $350. no problems with this one. I am lucky I did it my self and didn't pay for labor.
    I am not buying any parts like this from the autoparts store any more.
  8. Oct 24, 2010 at 1:24 PM
    coehorn1
    Could there still be air in the pump body? Maybe a re-bleed needed?
    Anyone?
