Steering too tight?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Caduceus, Dec 1, 2009.
  1. Dec 1, 2009 at 7:30 PM
    Caduceus
    Caduceus [OP] Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    One of the other threads mentioned needing to drive in 4-hi monthly to keep things lubed up. Anyway, today I did (only the second time in my 4 months), and for the recommended 10 miles.
    I noticed real quick that the steering really resists turning, especially right turns. Popping it back into 2-H and the steering is back to what I'm used to.
    Is this normal? I don't recall my Explorer doing this in 4-hi or 4-lo.
  2. Dec 1, 2009 at 7:43 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    yes, its normal. with the front end engaged, its resisting the one wheel spining more than the other while turning, so you really feel it in the turns. I do mine on the 1st of every month ( easy for me to remember ). I usually find a long straight road, a side road with no traffic. Put it in 4-hi for a mile or two, check traffic, stop and put it in 4-lo and do about a half mile. Stop and put back in 4-hi, go a few yards, then back to 2-hi. So i only do it for about 3-5 mile if that. But i have been doing this on my last 3 toyotas for over 20 years and have never had a driveline problems. Plus you then become real used to how your truck reacts.
  3. Dec 1, 2009 at 8:05 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    yeap,the resistance !
  4. Dec 2, 2009 at 12:44 AM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    15 DCSB TRD Sport 4x4 - Pyrite Mica
    I always found it interesting that I was not told of this when I bought the vehicle... this was my first 4WD truck and I was not aware of this until a few months ago. I can't find mention of it in the manual, either... only the upper speed limit for 4HI.
  5. Dec 2, 2009 at 2:20 AM
    Caduceus
    the Lowcountry
    09 DCSB TRD 4x4
    Yeah I wasn't told either. BTW, it's under the 4-wheel drive section, NOT preventitive maintanence (which to me would make more sense).
    It's literally a 2-liner in the manual. Go figure.
    OK, glad it's not unusual then. Thanks!
  6. Dec 2, 2009 at 5:56 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You shouldn't engage 4wd on pavement, only on surfaces that will allow slip. Otherwise, you're putting undue stress on the drivetrain. (Dirt, snow, ice, ect.... all good for 4wd)
    If you do have to engage it on pavement, only do it in a straight line as much as possible.... but best to avoid.
  7. Dec 2, 2009 at 6:43 AM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    yeap:D
