steering vibes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LBtaco, Jul 22, 2009.
what rims do you have vibrations with?
Poll closed Aug 21, 2009.
  1. 16" stock alloy(TRD OR) (SR5)
    11 vote(s)
    32.4%
  2. 17" stock alloy(TRD sport)
    8 vote(s)
    23.5%
  3. 16" stock steel
    7 vote(s)
    20.6%
  4. other
    8 vote(s)
    23.5%
  1. Jul 22, 2009 at 7:53 PM
    LBtaco
    LBtaco [OP] Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    Just wondering , the people getting vibrations in the steering wheel at around 55+ mph , what rims are you using?
    I had vibrations for a while, took a bit but they are gone now.
    combination of bad balance, possible "warped" rotors and over tightening of the lugs
  2. Jul 22, 2009 at 8:06 PM
    thomasr1950
    thomasr1950 16 Tacoma TRD Sport
    central us
    16 Tacoma TRD Sport
    I have a similar issue. Around the same speed up to 75+, also when slowing down around 35 using my brakes. I don't seem to notice it while coasting. I'm having my dealer check it out again this Fri., tires were rebalanced not too long ago, that helped but it seems to have come back. I'll post my results.
  3. Jul 22, 2009 at 8:13 PM
    Coastie Joe
    Coastie Joe Well-Known Member
    Andy
    NM
    16 TRD Off Road
    No vibes here! My 09 TRD Off Road is Tight as a ducks ass!!! :D
  4. Jul 22, 2009 at 8:14 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    How do you know how tight a duck's ass is???
  5. Jul 22, 2009 at 10:01 PM
    LBtaco
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I do know a duck's Va jay jay is corkscrewed... so I assume the ass is tight lol
  6. Aug 13, 2009 at 2:01 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    Can't vote because I got zero vibes......
  7. Aug 13, 2009 at 5:53 AM
    thomasr1950
    central us
    16 Tacoma TRD Sport
    Had a road force balance done, still have vibes. Now dealer says they used the wrong adapter. Not sure if i should give them a 3rd try or not. Toyota says if i go to another dealer i may have to pay a diagnostic fee! They aren't helping me like i thought they would.
  8. Aug 13, 2009 at 6:47 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    I think a better question is what tires are on those wheels.
  9. Aug 13, 2009 at 6:50 AM
    thomasr1950
    central us
    16 Tacoma TRD Sport
    Bridgestone H/T Duelers, came on truck with the stock wheels on the TRD sport pkg.
  10. Aug 13, 2009 at 7:28 AM
    Capita
    Have the Duelers too but with no vibes. Quite please with them
  11. Aug 13, 2009 at 11:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Most vibes around the 55 to 65 mph mark, are to to impropper tire ballance. Find a reputable shop that has the correct adapters, and have them balance the tires. As long as the tires are not out of round, and the wheels are free from defects, the truck should be vibe free.
  12. Aug 13, 2009 at 12:09 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    +1, Almost all steering vibes are from a improper tire balance, unless your front end is falling apart.
  13. Aug 13, 2009 at 2:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You mean Tire ballance. ;)
  14. Aug 13, 2009 at 6:29 PM
    bermise
    Houston
    08 TRD off road
    Yes, yes I do. good catch.
  15. Aug 13, 2009 at 6:46 PM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    2.5 King RR in front, LR ucs' s, 2.0 King RR rear, B.A.M.F shock mounts, ATO shackle flip, 4X sliders, ARB front bumper with XRC8, CBI hc rear, weathertechs, Leer cap, Thule rack, ubolt flip, etc.
    When you get your tires balanced next time, watch the guy that is doing it. I rotated my tires and balanced them like 500 miles ago +/- and I was getting a vibration from 65-70, it was pissing me off pretty bad so I took the rim back off and spun it 180 degrees because it balanced kind of heavy. After that I think it only needed like 2.50 ounces of weights, well the vibration was still there so I took the tires of the rims and kept the tires where they were at, moved the heavy rim to the right rear and rebalanced them. Now, it rides good like it should. So watch the guy and if the weight is still good maybe try having them switch the rims out. Unless it's time for a rotation, then go ahead and do that. Tim.
  16. Aug 19, 2009 at 2:33 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    It happens, LOL! :eek:
  17. Aug 19, 2009 at 6:08 PM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    if u r its alignment issus
  18. Aug 21, 2009 at 10:17 AM
    bermise
    Houston
    08 TRD off road
    If your steering wheel is wobbly or vibrating, you most likely need your tires balanced.
