Steering vibration - Rack bushings?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Skynet Surfer, Sep 17, 2020.
  1. Sep 17, 2020 at 10:26 AM
    Skynet Surfer
    Skynet Surfer [OP] Well-Known Member
    Dis
    15 DC v6 SR
    Hood struts Weathertech floor mats Roll n lock bed cover With custom Yakima rack over the bed Poploc tail gate Bed mat Retrofit source led fog lights Hitch and or 4 pin wiring Or just random small crap!
    I have a 15 4.0 4x4 dc with 80k. For quite some time now I have had a steering wheel vibration. I recently replaced the outer tierods and got an alignment. Now it feels better but on the freeway, I get a vibration. Now, this vibration feels like the wheels are going left and right intermittently. Sometimes it is nearly unnoticeable on smooth sections. While other times it fully shakes the wheel like 1/4 in back and forth. With reading a few threads it seems some have replaced the rack bushings. I'm thinking of trying this. I feel at even low speeds that it feels a little clunky at times. So I wanted to see what other people think about this issue on a stock suspension truck with TRD pro wheels. I'm thinking about some polyurethane bushings from Energy. The install seems simple and the solution seems mostly accurate.
  2. Sep 17, 2020 at 10:28 AM
    eon_blue
    Azusa, CA
    In my experience, the best way to tell if you need steering rack bushings is to take a look at your steering rack from under the truck while a friend turns the wheel side to side.
    When my rack bushings were shot, you could visibly see the rack moving/twisting when cranking the steering wheel
