Steering Vibration
Discussion in 'Suspension' started by taconerd, Nov 10, 2009.
  1. Nov 10, 2009 at 10:42 PM
    taconerd
    taconerd [OP] Member
    07 Tacoma SR5 PreRunner
    Bilstein 5100's front at 2.5" w/ .5" spacers and matching rears with Toytec AAL, 17" Matte Black Pro Comp 7089's wrapped with BF Goodrich 265/70/17 A/T KO, Satoshi grill mod, Cobra 75 WX ST CB Radio
    I have an 07' Tacoma 4Dr, short bed, with 5100's in front w/ 265 BFG AT
    I have had the alignment, balance and rotation done about 4 time since I had this set up on the truck.. Since then I have had unusual steering wheel and over all vibration while driving the truck. I had the alignment done 4 times and still having issues. Does any one else experience these same issues?
    Could this be a touchy Rack and Pinion in combination with the stiffer 5100's making the road imperfections felt more?
    Your input is greatly appreciated. :D
  2. Nov 11, 2009 at 5:06 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    maybe mud on back side of wheels/tires worn out/seperating.:notsure:
  3. Nov 11, 2009 at 5:56 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    I'd suggest getting your wheels road force balanced at another place..goodyear? Then see how it drives. I've had problems where one place couldn't find a problem and the other did.
  4. Nov 11, 2009 at 6:14 AM
    tacoterra
    tacoterra Batang SMB
    South NJ
    11 T4runner TE
    Ive had that issue with that same set up @ first but it turned out its all the tire techs balancing.A lot of tire shops hire tire techs with very minimal experience.balancing big tires is hard.some will just accept 50-75 ounce difference and that can ruin the whole thing.Ask them to do dynamic mode and if possible watch the machine #s.should be zeroed to get good balancing.I would suggest you to try other tire shops as well.
  5. Nov 13, 2009 at 7:27 PM
    taconerd
    Thank you for all the input...Much Appreciated!!!:)... I had the set put on at 4wheel parts about 4 months and had the Aliment done 4 times at 2 different Firestone's and once at 4wheel parts with balancing....I'm beginning to think it may be the balancing too.... Thanks again...
