Steering wandering and follows ruts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hoff, Jul 18, 2016.
  1. Apr 14, 2017 at 6:59 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I don't notice my Tacoma doing this. I had an '81 Oldsmobile that would do this so bad you could take a nap and the car would just follow the ruts along.
  2. Apr 14, 2017 at 7:05 PM
    Lt. Dangle
    Ohio
    I've got Goodyears.
  3. Apr 14, 2017 at 8:27 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    OP, get caster adjusted.
  4. Apr 14, 2017 at 10:47 PM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Negative Caster is your problem , positive caster using light racing arms are your solution.
    sucra likes this.
  5. Apr 15, 2017 at 6:28 AM
    MetrickMetal
    MetrickMetal Praise the Lowered
    Scott
    Yerington NV
    2017 Super White SR5 Access Cab / 4WD, AT / TP
    See my sig for mods
    It's also known as the rut avoidance device.
  6. Apr 15, 2017 at 6:43 AM
    TheCookieMonster
    TheCookieMonster cookies!!!!!!!!!!!
    North East
    1995 Hi Lux 22re 4x4 5speed
    Michelin MS2 K&N drop in filter
    its the Anti gravity mechanism in the steering box, its either defective or needs to be topped off with more AG fluid. take it back to the dealer demand an upgrade or check the AG fluid level to make sure its at proper level.
  7. Apr 15, 2017 at 6:47 AM
    MetrickMetal
    Scott
    Yerington NV
    See my sig for mods
    Dry casters can cause steering problems, so try applying a liberal amount of castor oil to you're casters and see if that helps
  8. Apr 15, 2017 at 8:58 AM
    Hiluxski
    Ventura California
    Go to A different alignment shop , what was your caster ? Remember the words "in spec" could mean a lot of different things to a lot of different people. there is a broad range and yours is right on the edge of too Low, But it could still be within spec and drive terrible. you need added castor !
    sucra likes this.
  9. Apr 15, 2017 at 12:13 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Did you plus size the tires?
  10. Apr 15, 2017 at 12:31 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    It's the archer, not the arrow
  11. Apr 15, 2017 at 12:36 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    This is just horrible. Does it follow ruts all time?
    sucra likes this.
  12. Apr 15, 2017 at 12:49 PM
    GPsevinSixx
    Ros Angerus
    I don't recall anyone saying he was bad at it or dishonest. He just might not be setting up caster angle to help you with the unsettled steering feel you're getting. "In-spec" as your shop states, is not solving the problem you're describing.
    Factory service manual states caster ranges are between -0.75° to +2.16 depending on your model. Do you have the printout of the alignment?
  13. Apr 15, 2017 at 1:43 PM
    SWB Tacoma
    Arkansas
    How does it do when you go into a curve that has a slight grade to it?
  14. Apr 15, 2017 at 1:57 PM
    SWB Tacoma
    Arkansas
    I would think if it isn't just roads causing tires to wander. It is probably just tires.
  15. Apr 15, 2017 at 2:00 PM
    #35
    SWB Tacoma
    Arkansas
    Do you know what tread depth is on tires? Lot of times tires with decent tread depth will have a tendency to wander. Also what does the tire pressure suppose to be?
  16. Apr 15, 2017 at 2:01 PM
    #36
    Clay7160
    Clay7160 Well-Known Member
    2018 MGM TRDOR DCLB 4x4
    GYEON ceramic coating
    The width of your truck might just fall right into the ruts, i've noticed in my fathers Dodge Dakota it does the same thing, but not in my Lexus or my Honda Fit, which are both wider and narrower cars.
  17. Apr 15, 2017 at 2:05 PM
    #37
    Hoonatic
    Hoonatic Well-Known Member
    PDX
    2017 TRD OR DCLB
    I'd say you have a bigger problem if your truck didn't follow ruts. Never driven any auto that didn't want to stay in a grooved road surface once in the channels.
  18. Apr 15, 2017 at 2:08 PM
    #38
    Hoonatic
    PDX
    2017 TRD OR DCLB
    So, it's all because of those wicked Subarus with studded tires, huh? Here I was thinking that all the tractor trailers who chain up at the first sign of a snowflake had something to do with it. Guess I was way off.
  19. Apr 15, 2017 at 2:22 PM
    #39
    SWB Tacoma
    Arkansas
    What pressure does it call for on the tires? It is on the tire on one side or the other.
  20. Apr 15, 2017 at 2:45 PM
    #40
    Clay7160
    lower the pressure to 36 see if that helps
