Steering wheel and truck vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Streeter57, Oct 11, 2023.
  1. Oct 11, 2023 at 8:53 AM
    Streeter57
    Streeter57 [OP] Well-Known Member
    16 trd sport access cab
    3 inch lift
    Right around 40-55 I get a vibration in the steering wheel when it’s a turn going straight I get a good vibration through the whole truck from 60-80 this is a 2016 trd sport tacoma
  2. Oct 11, 2023 at 8:55 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^You need to get the good vibrations diagnosed by a master tech. I suggest Mark Wahlberg.
    ClassyTacos, Rogue4, VB25 and 2 others like this.
  3. Oct 11, 2023 at 9:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    Rotate tires front to rear. Does the vibe move from steering to seat?
    Any suspension mods?
    Tire type/size?
    4wd?
    TRDRed, MadDaddy and Chew like this.
  4. Oct 11, 2023 at 9:03 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    My guess is that you have an out-of-balance wheel.
    airmax233, Merling, joba27n and 3 others like this.
  5. Oct 11, 2023 at 9:16 AM
    Streeter57
    3 inch lift
    They are 33’s with a 2.5 front and 2 inch rear lift I’ve got brand new falkon wild peak at3ws on it Less then 500 miles and 1.25 inch spaces also 4wd
    TRDRed likes this.
  6. Oct 11, 2023 at 9:20 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    FYI- Your posts are hard to read, maybe throw in some punctuation.
    The vibration started with new tires?
  7. Oct 11, 2023 at 9:26 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Rotate tires, see if the vibe changes
  8. Oct 11, 2023 at 9:30 AM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    tire balance.
  9. Oct 11, 2023 at 9:33 AM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    What are your tires? How many ply? Do you regularly check PSI? Any chance they're cupping? If so, rotate front to back and monitor your PSI closely going forward. Enjoy the nub-nub-nub sound for the next 40k miles.
  10. Oct 11, 2023 at 9:39 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
  11. Oct 11, 2023 at 9:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Are the wheel spacers hubcentric? Are the spacers torqued by torque wrench? Did you clean the hub surfaces on both sides of the spacer before install?
    ^If "yes" to all the above, go get your tires balanced by a different shop.
  12. Oct 11, 2023 at 10:09 AM
    Deeahgee
    Deeahgee Well-Known Member
    Just trade it in
  13. Oct 11, 2023 at 10:39 AM
    Streeter57
    3 inch lift
  14. Oct 11, 2023 at 11:09 AM
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    Press ECT for enhanced feelings :rofl:
  15. Oct 11, 2023 at 12:58 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Warped brake rotors will cause that to along with tires out of balance, or just bad set of tires.
  16. Oct 12, 2023 at 8:09 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Road force balance the tires and check alignment.
  17. Oct 12, 2023 at 8:16 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    No and No. Neither are needed to fix this problem. Road force is an absolute joke and alignment doesn't cause vibrations.
    My first troubleshooting suggestion would be to take off the spacer and see what happens. If you still have the problem then it is likely the wheels or the tires. A tire shop would be the best to sort this out.
  18. Oct 12, 2023 at 8:17 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Have you always had these vibrations? Or did they begin after lift/tire install? The answer is more than likely in that question.
    Here's your steps, from easy/free - not easy/not free:
    -*while driving in a straight line safely*, switch into 4HI and see if the vibes go away; if so, diagnosis is needle bearing - due to lift
    -grease your drifeshaft.. you'd be surprised how many ppl have never done this; yes, you need to do this; its a 2016 and still has zerks - newer models don't
    -remove spacers - check for vibes; you might not be using the correct type of spacer for the job
    -get a road force balance; it goes without saying tires need to be balanced properly
    -get an alignment - you're lifted now, your old alignment isn't sufficient; while the alignment may now cause vibes, a bad alignment leads to wear and tear on other components that will cause vibes.
    If none of those fix your problem, borrow some wheels from someone else. Ensure your wheel/tire combo is or isn't the source of the problem. Could have a bent wheel. If all of this doesn't fix your vibes, look into transmission shudder maybe.
  19. Oct 12, 2023 at 12:23 PM
    Sungod
    St Augustine
    Again, no need for a road force balancer. That is a gimmick from Hunter. All that is needed is a properly calibrated balancer with a tech that knows what they are doing.
  20. Oct 12, 2023 at 12:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    If OP got the 285-wide 33" tires like most people, the wheel spacers are necessary to clear the suspension. He would need another set of "known good" wheels + skinny tires to verify things this way.
