Steering wheel audio controls won’t work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JimmyTacoma09, Oct 25, 2023.
  1. Oct 25, 2023 at 12:56 PM
    JimmyTacoma09
    JimmyTacoma09 [OP] New Member
    James
    2009 Toyota Tacoma 4x4
    Stock
    I have an 09 Tacoma with audio controls on the steering wheel and also controls for the hands-free phone system through Bluetooth. These just stopped working. the truck has almost 400,000 miles on it so I expect for things to start falling apart but there is zero damage to anything that involves the steering wheel. I’m new here so please be easy on me.
  2. Oct 25, 2023 at 1:33 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    clock spring most likely, it is a ware item
    JimmyTacoma09[OP] and ToyoTaco25 like this.
  3. Oct 25, 2023 at 1:52 PM
    naitdaug
    naitdaug Member
    2006 Double Cab 4WD
    Leer Topper
    Yeah, clock spring aka spiral cable, which I just replaced and there are plenty of tutorials out there. I got mine on eBay for $15
    JimmyTacoma09[OP] likes this.
  4. Oct 29, 2023 at 10:58 AM
    JimmyTacoma09
    James
    Stock
    Is it also called an airbag clock spring?
  5. Oct 29, 2023 at 7:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes
    It's the path for any/all electronics on the steering wheel to connect to the rest of the vehicle
    OEM is expensive, some guys try their luck with aftermarket
  6. Oct 29, 2023 at 8:42 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Is this an aftermarket radio? If so, there may be a little electronics box that interfaces the str whl controls to the radio. It could have gone bad
  7. Oct 29, 2023 at 8:45 PM
    lr172
    ‘11 DCLB 4.0 Auto
    It is usually just a ribbon cable coated in grease and loosely wapped many times around a cylinder. I tore one apart on a cherokee and soldered back the broken trace. I was going to the bitter end befoe i gave chrysler $350 for $1.50 in cable. They call it a clockspring as it probably once was that, but today there are no springs.
  8. Oct 29, 2023 at 8:49 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I don't know about grease but yea it's a ribbon cable wrapped up in a plastic housing
  9. Oct 31, 2023 at 9:06 AM
    JimmyTacoma09
    James
    Stock
    Thanks everyone for setting me in the right direction. I should have it tomorrow. Hopefully it’ll work. Stock radio, but it thumps so I didn’t need to replace it. Now it’s on to headlights, grill and front fender. Deer. Any suggestions on getting those cheaply?
