Steering Wheel column loose tilt adjustment
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1997tacomav6, Mar 27, 2019.
  1. Mar 27, 2019 at 7:25 AM
    1997tacomav6
    1997tacomav6 [OP] V6 5sp,RegCab,TVS1320 Supercharger,Haltech, 800k
    Denver
    anyone have this issue and or a fix?
    My steering wheel about a month ago developed 1/4-1/2” of extra play.
    It feels like the whole steering wheel and column are coming loose and when I hit any bumps
    it feels like it’s jumping all over the place.
    If you grap the steering wheel top and bottom and push the wheel up and down there is almost 1/2” play. But there is no play if you do this left to right. Almost feels like the bolts holding the column to the frame have come loose.
    Steering wheel and column have never been removed before.
    Any ideas where to start looking?
    Also has tilt steering
    Steering rack and ujoints were replaced a year ago by dealer.
  2. Mar 27, 2019 at 7:51 AM
    Glamisman
    Glamisman Well-Known Member
    there is a thread on this on the forum somewhere regarding the collapsable column and how they "fixed" it. I think they disassembled the column and tack welded the collapsable portion together. Is this your issue, I dont know, I know that it only really effected a certain year of Tacomas.
  3. Mar 27, 2019 at 7:59 AM
    1997tacomav6
    Denver
    Yes I read that thread but I have NO play from right to left and only play from top to bottom.
    If it was the pin or joint I would think the play would be in both directions left to right and top to bottom
  4. Mar 27, 2019 at 8:05 AM
    tcjacado
    tcjacado Well-Known Member
    I have seen a thread where the steering wheel is loose. Get the cover off and there should be a nut that holds the wheel down. Check there first.... or can you physically feel the entire colomn moving up and down?
  5. Mar 27, 2019 at 8:07 AM
    1997tacomav6
    Denver
    It’s the whole column and steering wheel you can feel move up and down, not sideways ,
    Because it’s a tilt didn’t know if something in there area was going out
  6. Mar 27, 2019 at 8:10 AM
    tcjacado
    Could be that the lock to keep it in one place is losing its pressure/ability to keep it in place. I would pull the column cover and play with he tilt mechanism.
  7. Mar 27, 2019 at 8:17 AM
    Clearwater Bill
    Billy
    Largo Florida
    You'll know if you watch the column under the dash while moving up and down at the wheel.
    It won't move as much as the wheel as its closer to the pivot point, but you'll be able to rule out the tilt mechanism.
  8. May 8, 2019 at 10:30 AM
    1997tacomav6
    Denver
    So took the steering wheel and column out,
    The tilt mechanism was actually the problem with 1/2” play from north to south position in the wheel not left to right.
    Of course they don’t have the parts of sale anymore.
    Found a complete steering wheel column with the tilt from a truck with 130k for 100.00.
    So that was my fix, it’s going in today.
    Ritchie likes this.
