Steering wheel control problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoOwner, Mar 13, 2016.
  1. Mar 13, 2016 at 9:25 AM
    TacoOwner
    TacoOwner [OP] Member
    Pat
    California
    Dbl Cab Short Bed 4X4
    Pro-Comp 6" Lift/33" Wranglers/Detroit TrueTrac Diff
    HI guys, I recently replaced my head unit with a JVC in my 2011 Double Cab. I used the PAC kit from Crutchfield to transfer the steering wheel controls. Then something strange happened; for a while the horn worked fine, then it only worked when the wheel was turned. Now it doesn't work at all. I live Cali, so the horn is used in conjunction with the finger. I was thinking I would just locate the wire in the harness and wire it directly. Any help with this would be appreciated. Does anyone know what color wire it is in the harness? Or a better solution? Thanks, this forum has been great help.
