Steering Wheel Controls Don't Work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TrdACOMA, Jun 30, 2013.
  1. Jun 30, 2013 at 1:37 PM
    TrdACOMA
    TrdACOMA [OP] Member
    Carter
    Utah
    '05 Tacoma TRD SR5
    Hey guys, I'm new here.
    I just picked up an 05 Double Cab TRD Tacoma with the 6 speed trans from the dealership that I work at.
    I can't get the steering wheel controls to work. I searched about it and I can't find anything. What could be wrong?
  2. Jun 30, 2013 at 2:25 PM
    llibrm
    llibrm OH NOOOOOO!
    Bill
    Winthrop, WA &Convection Oven, AZ
    06 DCSB, 06 LC120 (sold)
    Pelfreybilt Aluminum Bumper, KING 2.5 on all four corners, 4x4 illuminated switch, Cobra 75 w/ 3' Firestick, 2M/ 70cm Radio w/ Diamond NR770HB, Pelfreybilt bed bar, Lightforce Stiker 170s, BD 20" OnX6, BD S2 ditch lites on SDHQ mounts, BD SAE Fogs
    I'd pull the had unit first and check all the connections. After that...Hmmm
  3. Jun 30, 2013 at 2:33 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    'I just picked up an 05 Double Cab TRD Tacoma with the 6 speed trans from the dealership that I work at'
    you just bought it, take it back to the place you work/purchased truck and get it fixed on their dime...
  4. Jun 30, 2013 at 3:06 PM
    ailll1
    ailll1 Well-Known Member
    Alex
    Québec, Canada
    2016 Tacoma Trd Sport Double cab
    Aftermarket HU?
  5. Jun 30, 2013 at 4:02 PM
    ANT2013taco
    ANT2013taco Well-Known Member
    McAllen Texas
    13 TRD OR 4wd
    The original owner probably had an aftermarket radio in it, definitely pull the head unit and check connections. Also, check to make sure that it is the correct head unit and not just off the dealer old stock storage which may not have SW control capabilities.
  6. Jul 1, 2013 at 9:24 AM
    TrdACOMA
    Carter
    Utah
    '05 Tacoma TRD SR5
    Thanks guys.
    Yeah, I bought it "as is" from them, and since I am an employee and got employee pricing it is on me to fix. Ill definitely pull the head unit and check connections. I found some RCA cables near the driver side rear seat so I am guessing that he might have had an aftermarket head unit, or had a line drop installed. So I'll check that out first off and see what the deal is.
    Thanks!
  7. Jul 1, 2013 at 2:31 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Spiral cable in the steering wheel. There was a recall for it. If you decide to look into it yourself be careful as it also goes to the air bag.
  8. Jul 1, 2013 at 6:00 PM
    ee1284
    ee1284 Well-Known Member
    Louisiana
    05 Prerunner Sport
    Previous owner probably had an after market radio
  9. Jul 1, 2013 at 6:02 PM
    ee1284
    Louisiana
    05 Prerunner Sport
    I just recently put my stock radio back in. If the connector is missing i can send you a link to the harness I bought and how I wired it to work with the steering controls again.
  10. Jul 2, 2013 at 8:27 AM
    TrdACOMA
    Carter
    Utah
    '05 Tacoma TRD SR5
    Thanks guys! So I pulled out the head unit last night to install a factory aux cable deal and thought I would check on the connections while I was at it.
    Well I found 3 wires for the stock harness that look like they got ripped out / unplugged. but there were no metal connections left in the holes like for the connecters? I took a picture so let me get that posted. Maybe he took them out to make the factory plugs work with an aftermarket head unit?
    What do you guys think?
    Oh and you maybe send me that link just in case that's what I end up needing? I would appreciate it!
  11. Jul 6, 2013 at 9:06 AM
    TrdACOMA
    Carter
    Utah
    '05 Tacoma TRD SR5
    Could anyone maybe give me a wiring diagram for where the cables should go? I might call Toyota and see if they have any way of getting me some new connectors I could solder back on and fix the connections.
    Thanks!
  12. Jul 6, 2013 at 6:58 PM
    ee1284
    Louisiana
    05 Prerunner Sport
  13. Jul 6, 2013 at 7:16 PM
    UrPebkac
    UrPebkac Well-Known Member
    David
    RI
    2016 GMC SIERRA
    Those 3 striped wires are the controls. You need the R3 connector. Have the dealership look it up.
    The wires goes in the R3 connector in this order
    Pin 6 white W/ red stripe
    Pin 7 purple W/ white stripe
    Pin 8 yellow W/ black stripe
    You will need the pins to put the stripped wires back in the R3 connector. I don't know the part numbers but I am sure they can be found on mouser.com maybe even these. http://www.mouser.com/Search/ProductDetail.aspx?R=1123343-1virtualkey57100000virtualkey571-1123343-1
  14. Jul 6, 2013 at 7:28 PM
    TrdACOMA
    Carter
    Utah
    '05 Tacoma TRD SR5
    Oh awesome! Yeah it looked like I was completely missing the connector. I'll have to check it out at the dealer, or even see if I can get one through the dealership that I work at.
    Thanks a bunch guys, I really appreciate it!
  15. Jul 6, 2013 at 7:33 PM
    UrPebkac
    David
    RI
    2016 GMC SIERRA
    Your welcome. The R3 connector looks like this. The PIN numbers is flipped. If you where looking at the connect as if you where about to put the wires in it would read
    10 9 8 7 6 5 4 3 2 1
    20 ....................11
    You get the idea.?..
  16. Jul 7, 2013 at 11:32 AM
    TrdACOMA
    Carter
    Utah
    '05 Tacoma TRD SR5
    Oh yeah I see what you're saying. So in the diagram it is showing the numbers as if you were looking at the front of the connector with the wires going out the back. Correct?
    So I need to wire it as if it was like you said.
  17. Jul 7, 2013 at 5:55 PM
    UrPebkac
    David
    RI
    2016 GMC SIERRA
    Correct. Just replaced my 07 HU with a 2013 touchscreen. Those 3 wires I had to relocate to the new connector (r15)
    also added a scion IQ mic for the Bluetooth.
    Just finished it yesterday. It was fresh in my mind.
  18. Jul 8, 2013 at 9:43 AM
    TrdACOMA
    Carter
    Utah
    '05 Tacoma TRD SR5
    Oh crap that looks really good in there. How much did that cost you?
    And that's awesome, thanks again! I really appreciate all your guys' help! I'm looking into getting that connector today so hopefully I can figure something out!
  19. Jul 8, 2013 at 12:13 PM
    UrPebkac
    David
    RI
    2016 GMC SIERRA
  20. Jul 8, 2013 at 3:24 PM
    TrdACOMA
    Carter
    Utah
    '05 Tacoma TRD SR5
    Oh that's awesome, such a good deal! That's what I need to find. That would be really nice. You just had to get a harness for it all to hook up right? Or is the factory harness made to work with the touch screen head unit also?
