Steering wheel controls getting weird
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hherby, Dec 11, 2022.
  1. Dec 11, 2022 at 2:26 PM
    hherby
    hherby [OP] Member
    Oklahoma
    2012 Tacoma
    King 2.5 all around C4 front and rear bumpers and a GFC
    ive recently noticed that when i turn my headlights on my steering wheel controls get weird.
    heres my situation:
    Headlights - on
    Occasion 1
    volume down - works
    volume up - nothing
    back track - nothing
    forward track - does what the back track button is supposed to do
    Occasion 2
    volume down - nothing
    volume up - works
    back track - does what the volume up button is supposed to do
    forward track - does what the back track is supposed to do
    Headlights - off
    everything works as it should
    any help or insight as to where to start chasing this gremlin would be much appreciated
  2. Dec 17, 2022 at 6:23 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    If you have the factory head unit, I would name that as the #1 suspect. The way the steering controls work is that each button has a separate resistor value, and when a button is pressed, the head unit detects the Ohm value coming over the wire and translates the input accordingly. The factory head units are prone to odd behavior over time (buttons on the head unit not working/doing the wrong thing) and it would not surprise me in the slightest if yours was having issues with the steering wheel inputs as well.
    There's no fix for the head unit itself, short of tearing it apart and doing low level component checks/repairs - the fix is to replace it with a used factory unit ($$$$/likely to die again) or an aftermarket unit.
  3. Dec 17, 2022 at 6:28 AM
    hherby
    hherby [OP] Member
    Oklahoma
    2012 Tacoma
    i have an aftermaket headunit, all of the controls have worked with no issue for about 2 years, started acting up a few months ago
  4. Dec 17, 2022 at 6:32 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Then you may want to pop it out and check the steering wheel controls. It would be a matter of using a meter to verify the resistance of each button over the two wires on the vehicle side harness - I don't have a pinout or expected ohm values handy but I bet @caribe makaira does.
    If the values are not as expected, your problem is either resistors gone bad (unlikely), a faulty/sticking button/contact, or an issue with the clockspring causing intermittent failure.
    wilcam47 likes this.
  5. Dec 17, 2022 at 6:37 AM
    hherby
    hherby [OP] Member
    Oklahoma
    2012 Tacoma
    cool thanks, later today ill pull it apart and see if i get different readings for each button press
  6. Dec 17, 2022 at 6:39 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Well, you'll also want to make sure they're the correct different readings. If one button is sticking, it will cause them all to be off by that amount, e.g. if an 80ohm resistor is sticking, one that is supposed to read 50 to read 130, etcetera.
  7. Dec 17, 2022 at 6:45 AM
    hherby
    hherby [OP] Member
    Oklahoma
    2012 Tacoma
    sounds like i need to test it with the headlights off and then see if they are different with the headlights on
    deanosaurus[QUOTED] likes this.
