Steering wheel conversion with Radio controls
Discussion in '1st Gen. Tacomas (1995-2004)' started by mechanicjon, Jan 28, 2018.
  1. Jan 28, 2018 at 11:45 AM
    mechanicjon
    mechanicjon [OP] They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Official write up with more info here.
    https://www.tacomaworld.com/threads...tooth-phone-controls-offical-write-up.537400/
    The Airbag is the 2 wire type. The 2002-2005 Sequoia uses a single wire airbag and some older Tundra's as well as Camry's. So I'm looking for a different airbag now.
    This clock spring will fit our column mounting locations and has the correct plug for the controls and single airbag. https://www.amazon.com/QKPARTS-Spring-Toyota-Sequoia-2002-2005/dp/B077Y8PHB2
    The wire connectors from the column to the clock spring assembly I'm still researching.
    Most after market radios will work with steering wheel control interface. If you have a Pioneer head unit check this info. http://jvde.net/node/7 Since most controls work off resistance This Pioneer hack may work for other head units. Just google search for your brand. Connector for radio controls:
    EDIT: Looking like using a interface module would be the cheapest and easiest to hook controls up to HU.
    Connector for cruise control and cruse control stalk. All the resistance for each button appears to be the same as ours. So the CC should be just pinning the plug correctly to match ours.
  2. Jan 28, 2018 at 11:45 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Parts list so far:
    1. Steering wheel with factory radio controls and wire harness some: 03 Sequoia, ? Landcruiser, 4th gen 4Runner, ? Camry and 2nd gen Tacoma's.
    2. Airbag with single connector: 03 Sequoia could be other years or model Toyotas.
    3. (Optional) Bluetooth Cell phone control option. Part number is for: 4th gen 4Runner, ? Camry and ? Landcruiser. According to Camelback Toyota.
    Switch $77.04 part #84244-35030-B0 is for the gray color. Looks black, tan was the only other option.
    Cable $30.37 part #84204-58010
    4. Clock spring:
    more to come and pics
  3. Jan 28, 2018 at 1:00 PM
    tony2018
    tony2018 Well-Known Member
    I always wondered this, sub'ed.
  4. Jan 28, 2018 at 4:03 PM
    areax
    areax New Member
    Interesting. Looking forward to see how this turns out.
  5. Jan 29, 2018 at 6:59 AM
    SparkyIX
    SparkyIX Well-Known Member
    Anthony
    Tonopah, AZ
    2009 TM 4x4 DCSB 6-Speed Swap
    Sub’d
  6. Jan 29, 2018 at 7:40 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
  7. Jan 29, 2018 at 8:20 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Also looking into adding the Bluetooth phone controls on the right side of wheel.
    Speedytech7 likes this.
  8. Jan 29, 2018 at 8:23 AM
    gearcruncher
    Canadain bumper technician
  9. Jan 29, 2018 at 8:24 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    funny @gearcruncher I was just reading your stereo build thread. 2004 4runner
    gearcruncher likes this.
  10. Jan 29, 2018 at 8:26 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    I need to find a 00-03 Tundra airbag since they only use 1 connector.
    Krazyoakes likes this.
  11. Jan 29, 2018 at 10:26 AM
    Krazyoakes
    Krazyoakes Well-Known Member
    Isaac
    Eugene, OR
    01 Tacoma 4x4
    I can most likely get you one if you need it.
  12. Jan 29, 2018 at 11:43 AM
    tony2018
    mechanicjon[OP] likes this.
  13. Jan 29, 2018 at 7:54 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Did you only hook up one side of Airbag? The one I have is a dual bag.
    EDIT: Your second gen so yours would already be a dual rate bag.
  14. Jan 29, 2018 at 8:37 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    well this is interesting.. i may look into this instead of the older sequoia wheel.. this looks cleaner.
  15. Jan 29, 2018 at 8:58 PM
    Empty_Lord
    Dan
    i do believe those had the same wheel as 01-04 Tacomas, the airbag wont fit. I know the 02 i just had at work was definitely the same wheel as my 01 taco.
  16. Jan 29, 2018 at 10:10 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    I needs to be a tundra wheel with the audio control options. There may be other years and models useable. I'm still researching it. The Tundra and Sequoia clock springs have the plug for audio controls with only 1 airbag plug. That's what has pointed me in this direction for model of vehicle.
  17. Jan 29, 2018 at 10:19 PM
    tony2018
  18. Jan 29, 2018 at 10:22 PM
    mechanicjon
    Jon
    Scottsdale Arizona
  19. Jan 29, 2018 at 10:29 PM
    tony2018
    but cant you change the cover
  20. Jan 29, 2018 at 10:32 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    No the actual spokes for the wheel are in different locations. I looked at swapping just cover to my airbag. It's completely different.
