Steering wheel crooked... alignment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacomax4, Sep 3, 2018.
  1. Sep 4, 2018 at 7:41 AM
    SargeBB
    SargeBB Active Member
    2008 Impulse Red regular cab 4x4 Tacoma
    OEM Cruise, OEM Intermittent wipers, 10-ply Michelins
    That alignment is not bad, except for front toe, which should be about .06 on each side. Also, even 'tho within specs, for my money, the camber should be closer to zero on each side. The thrust angle is okay...besides there's not too much can be done about it. Gotta get that front toe into spec., although you may have tire or brake problems as well...but I'd start with the front toe as you're wearing out your tires.
  2. Sep 4, 2018 at 9:04 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Rotate your tires,then take the truck back and have them check the alignment.
  3. Sep 4, 2018 at 1:17 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    It is .06 on both sides and the total toe is dead on. Shits mint.
  4. Jun 28, 2020 at 3:32 PM
    CP40
    CP40 Well-Known Member
    Toyota Tacoma TRD off-road 2020
    This is almost never the reason. Sounds good though.
    RoughRder likes this.
  5. Jun 28, 2020 at 6:23 PM
    RoughRder
    RoughRder What fresh hell is this?
    Garrett
    Hampton Roads, VA
    2011 DCSB TX TRD
    5100s and OME 885 coils front, 5100s and AAL for the TSB leaf pack (overload left in) rear. Jeraco camper shell.
    I know this is an old thread, but I had the same issue this past week. I hit something seemingly small, but it jolted the truck and after I noticed the wheel wasn’t straight. It drove straight down the road, but I had an alignment and my camber was off and they straightened the wheel.
  6. Jun 28, 2020 at 7:08 PM
    CP40
    I'm out in Nevada at the moment and I had it just happened to me today. At first. The steering wheel was crooked but the car drove relatively straight. Later along the day at highway speeds the car seemed to pull hard to the right. Hopefully I can get back to LA and get it checked out by my alignment people.
    The old story about the crown in the road though is almost never the case when you're talking about a crooked steering wheel or a pull
  7. Jun 28, 2020 at 7:54 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    The idiot who did my alignment didnt have my steering wheel perfectly straight when aligning it. Toe was perfect, so I just adjusted the tie rods and straightened my steering wheel and it drives straight as an arrow now.
