Steering wheel feels too "free" at highway speed
Discussion in '1st Gen. Tacomas (1995-2004)' started by RAT PRODUCTS, Oct 16, 2013.
  1. Oct 16, 2013 at 9:41 PM
    #41
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Get the inner tie rod replaced then, it's only $35 at Rock Auto (http://www.rockauto.com/catalog/moreinfo.php?pk=504266&cc=1429084). Even if the toe is set correctly, the fact the ball-and-socket joint in the tie rod can't move smoothly can give a stick-slip behavior and cause shimmy.
    Toe out will cause some wondering issues. 0.8 deg toe out contributes to the problem, but simply correcting toe likely won't cure your issue.
  2. Oct 17, 2013 at 1:45 AM
    #42
    SafetyDang
    SafetyDang get your facts straight
    Dang
    Anaheim, CA
    DC with 4x4 & MT Conversion
    Swapped to Manual Trans & 4x4
  3. Oct 17, 2013 at 3:52 AM
    #43
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    ah ok, I had a similar feeling but it ended up being the slip joint in the column. After tack welding it all is good.
    I believe you can replace just the seal in the rack if tack welding that joint fixes yours.
  4. Oct 17, 2013 at 6:35 AM
    #44
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I actually got pulled over once on the interstate because someone called me in thinking I was drunk. I attribute it to needing to tack the slip joint eventually (well mostly messing with my ipod or something, but that's beside the point). I've been putting it off, but now one of my orange lights behind the gauge cluster is out too so I need to tear the dash apart to get to both.
    Ryan, if you decide to do the slip joint thing lemme know. We can do them both at once (plus I don't have a welder :p ) I'll even be the guinea pig to go first so we can fuck mine up and get it right with yours haha
    Biscuits likes this.
  5. Oct 17, 2013 at 8:14 AM
    #45
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Get LR UCA's. You get additional Caster/Camber adjustments which allows you to keep your weels center (or push fwd/back) when adjusting caster.
  6. Oct 17, 2013 at 8:48 AM
    #46
    RAT PRODUCTS
    RAT PRODUCTS [OP] Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I will bring my little 120v welder from home and we can knock it out sometime. I hope the reward vs time is worth it.
  7. Oct 17, 2013 at 8:57 AM
    #47
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  8. Oct 17, 2013 at 9:18 AM
    #48
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Take a look at the TTORA thread. You can remove the whole assemly in like 6 bolts. Don't need to remove all of the trim, ducting etc.. Makes it an even easier job.
  9. Oct 17, 2013 at 9:25 AM
    #49
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    definitely tack weld the slip joint in the steering column. that made more of a difference on my two tacomas then the poly rack bushings. takes about 2 hours the first time you do it, but it's a very straightforward job.
  10. Oct 17, 2013 at 9:35 AM
    #50
    Digiratus
    Roaming the PNW
    The RedHead
    I was just reading that thread. Post #42 in the ttroa thread does simplify the column removal. Thanks.
  11. Oct 17, 2013 at 10:07 AM
    #51
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I am definitely using that as my defense!! "But, but officer, my caster is out of spec and I had to choose whether to put food on my family's table or to get some Total Chaos UCAs" lol
  12. Oct 18, 2013 at 7:48 AM
    #52
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Yep, 3 bolts, 2 springs, a few plugs and the clam shell trim just in front of the wheel. No need to even remove the lower trim panel at all.
    Needle nose vise grip pliers come in handy for letting the tilt springs know who is boss. Shimming up the pivot ball is also worthwhile.
    For non tilt wheels it is a little more involved but not by much. I have the dope on that if anyone wants it.
  13. Oct 19, 2013 at 3:20 AM
    #53
    SafetyDang
    Dang
    Anaheim, CA
    Yea I made the video before someone confirmed that there was an easier way.
  14. Oct 21, 2013 at 9:55 AM
    #54
    MowTaco
    Kansas
    I've tried the "I just got bigger tires and my speedo is probably off and I forgot about it until now" as an excuse for speeding like 3 times, still don't get let off.
  15. Oct 21, 2013 at 9:59 AM
    #55
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I put my sway bar back on and now the shake is a lot better. Live-able for sure.
  16. Mar 17, 2014 at 1:46 PM
    #56
    crazybrother
    crazybrother Member
    Does anyone have a link to the TTORA thread, I did a search but got 10 pages... I need to weld my steering column too but would like the easier way to remove it.
    Thanks.
  17. Mar 17, 2014 at 11:27 PM
    #57
    Digiratus
    Roaming the PNW
    The RedHead
    Here you go.
    ThunderOne and Biscuits like this.
  18. Dec 16, 2016 at 10:19 AM
    #58
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Ive been told using a roll pin works also? I don't want to do this if I have to remove the entire steering column.
    EDIT: nevermind, should've read the whole thread... may try some sort of set screw instead. I don't want to remove the steering shaft especially after some have reported problems of binding (never really got an answer as to why either)
