Steering Wheel Jitter
Discussion in 'Wheels & Tires' started by taconerd, Jun 30, 2011.
  1. Jun 30, 2011 at 9:59 PM
    taconerd
    taconerd [OP] Member
    07 Tacoma SR5 PreRunner
    Bilstein 5100's front at 2.5" w/ .5" spacers and matching rears with Toytec AAL, 17" Matte Black Pro Comp 7089's wrapped with BF Goodrich 265/70/17 A/T KO, Satoshi grill mod, Cobra 75 WX ST CB Radio
    Question.... I Have a 07 DC with billies 5150 billies all around on Procom 7089's with 265 BFGoodies... I have sooo much jitter in my steering wheel and always have since I got this set up. Can the wheel be out of balance instead of the tire on the wheel out of balance or is it just Tacoma's steering wheel jitter when you have the truck altered?
    Thank you in advance for your input.
  2. Jun 30, 2011 at 11:47 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    did you get an alignment?
  3. Jul 1, 2011 at 8:46 AM
    taconerd
    It's been aligned,balanced, rotated 5-times. It seems the balance is off on one of the wheels no matter what..that's why I'm wondering if the wheel can be off? Thanks again.
  4. Jul 1, 2011 at 7:33 PM
    ssmskot
    ssmskot Well-Known Member
    Maine
    '07 Base 4x4
    Soft Tonneau. Tint. Toyota bed mat. K&N Air Intake. 265/75/16 BFG AT's. Sport grille. Weathertechs.
    whats the hub bore size on the 7089's?
    Pretty sure I've read thru some other posts where people have similar problems because the bore size of the wheel is slightly larger than the trucks hub.
    Might need some hub rings to tighten everything up. Just a thought, I don't have aftermarket wheels so I don't know from experience.
  5. Jul 1, 2011 at 7:44 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    What speeds do you get the "jitter"?
  6. Jul 1, 2011 at 9:11 PM
    Rolltider29
    Rolltider29 Member
    Hartselle
    07 prerunner
    YES, YOU NEED TO MAKE SURE THE HUB BORE IS CLOSE AS POSSIBLE TO MATCHING UP. THIS WILL CAUSE VIBRATION. THE HUBBORE ON A TACOMA IS 110. THE TIRE OR THE WHEEL COULD BE OFF AS WELL. I SELL AFTERMARKET WHEELS, THIS IS A COMMON PROBLEM THAT CAN EASILY BE FIXED. LET ME KNOW IF YOU HAVE ANY MORE QUESTIONS?
  7. Jul 2, 2011 at 5:47 PM
    ssmskot
    Maine
    '07 Base 4x4
    Thought it was 106mm. No?
  8. Jul 2, 2011 at 7:54 PM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
    Go to Zuby's tire and wheel in Garden Grove. Get a road force balance done and kiss the jitters goodbye. Tell them Aaron sent you.
  9. Jul 3, 2011 at 6:25 PM
    taconerd
    O:mad:
  10. Jul 3, 2011 at 6:36 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    What I am going to suggest helped out another fellow member with the same issues.
    Look at the weights on your wheel, do you have 1 set of weights either in the middle of the rim or right behind the spokes OR do you have 2 sets of weights placed on the rim? A lot of the time with aftermarket wheels that use tape weights the tire shops will use just one set of weights (static) when most factory wheels use dynamic (weights on both sides of the rim). I would suggest going back to the tire store and asking them to do a dynamic tire balance with the correct hub adaptor on the balance machine.
    Hope that helps!
  11. Jul 3, 2011 at 6:36 PM
    08pretaco
    az
    i was also under the impression it is 106mm
