Steering wheel keeps popping out of center even after alignments
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AbeFroman2, Jun 24, 2023.
  1. Jun 24, 2023 at 1:19 PM
    AbeFroman2
    AbeFroman2 [OP] Active Member
    2011 TRD Sport
    As the title states, shop has fixed it twice and said everything looks ok but it keeps popping off center to the right after minimal off roading. One tie road was replaced a few months ago and the other one looks okay but I am thinking maybe not? Is the cause of this definitely going to be one of the tie rods? How do I know which one? The truck still tracks straight after this happens so I don't think it is affecting the alignment. Any help is much appreciated as this is getting annoying.
  2. Jun 24, 2023 at 4:35 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Would it be possible you have excessive play on your steering rack? Heard the bushings there aren't the greatest. Just guessing though.
    koditten likes this.
  3. Jun 24, 2023 at 4:42 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    This^
    I'd mark the rack with with a paint pen then next time you align it.
    When it drifts, get under there and look to see if the rack is moving.
  4. Jun 24, 2023 at 5:38 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Also, once centered, check the torque on your lower control arm hardware. I believe the torque on those should be 100 ft*lbs. Also, check that none of your alignment tabs are bent flat.
  5. Jun 24, 2023 at 5:40 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    Can also be lower control arm cams shifting around.
  6. Jun 25, 2023 at 1:49 PM
    AbeFroman2
    2011 TRD Sport
    Where all do I mark stuff? Thanks for the response.
  7. Jun 25, 2023 at 4:11 PM
    koditten
    Kirk
    Central Michigan
    Look for clamps type brackets that hold the rack. Put a mark at these locations. If something moves, even minutely, you will see the paint was disturbed.
    AbeFroman2[OP] likes this.
