Steering wheel off center by alot now...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MAG GRY TACO15, May 4, 2023.
  1. May 4, 2023 at 1:03 PM
    MAG GRY TACO15
    MAG GRY TACO15 [OP] Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Hit the mother of all pot holes today. My tie rod Dont look like they moved but not my steering wheel has to be in this position to track straight.... Since it's not the tie rods, how do I realign it?
    Sig45 likes this.
  2. May 4, 2023 at 1:04 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    :eek:
    r2pinter and HondaGM like this.
  3. May 4, 2023 at 1:04 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    You Need an Alignment..
  4. May 4, 2023 at 1:08 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Likely bent inner or outer tie rod. Or worse, other suspension parts bent.
    HondaGM and Rock Lobster like this.
  5. May 4, 2023 at 1:09 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  6. May 4, 2023 at 1:10 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Both outers looked okay. Can't see the inners b/c of the boot but i'll look at it closer when I get home
    HondaGM likes this.
  7. May 4, 2023 at 1:10 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Probably this!
    HondaGM[QUOTED] likes this.
  8. May 4, 2023 at 1:11 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    That front end is fubar…. You need an alignment ASAP.
    HondaGM likes this.
  9. May 4, 2023 at 1:12 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Check the alignment cams. I bet one moved. Possibly flattened a tab as well.
    Get it realigned.
  10. May 4, 2023 at 1:13 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Yeah, wasn't sure if it was like older cars and the steering shaft just needed to be adjusted with the wheel. Thought maybe since i was holding it and when it jolted it skipped a tooth on the shaft or something of that nature.
    HondaGM likes this.
  11. May 4, 2023 at 1:15 PM
    TireFire
    Olympic Peninsula
    Not as likely as just alignment knocked out
    cruxofthebisquit and HondaGM like this.
  12. May 4, 2023 at 1:16 PM
    Superdave1.0
    SoCal
    Good call. I change my answer to likely this!
    HondaGM likes this.
  13. May 4, 2023 at 1:19 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    They were still tight but I don't know where they were before as I didn't mark them after the last alignment so I don't know where to set it back.
    I haven't had an alignment since I changed out springs so I guess it's time. Got one scheduled for tomorrow.
    Thanks everyone.
    10thMTNgrunt and HondaGM like this.
  14. May 4, 2023 at 1:30 PM
    steveo27
    Pittsburgh
    Mark all the alignment cams.
    I blasted a huge rut dickin around in the woods a few weeks back and my wheel went to about 2 o’clock. Climbed under the truck, found one alignment cam had spun a hair because it was marked. Spun it back to the mark, re-torqued and the wheel is back to center.
    HondaGM likes this.
  15. May 4, 2023 at 1:32 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Looking at my passenger side rear it looks like it may have shifted. I'll give this a go first and see what it looks like.
    Any of you alignment guys know if turning that one counter clockwise would do the trick. I can't remember what direction turning the cam tabs affected how the LCA moved
    HondaGM likes this.
  16. May 4, 2023 at 2:17 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    One should never guess at alignment settings. Take it to a competent shop and let them make the proper adjustments or repairs.
    HondaGM likes this.
  17. May 4, 2023 at 2:37 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
  18. May 4, 2023 at 3:03 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    So everything tracks like it did before, no bent tie rods. Just the wheel is cocked.
    Looking at the shaft that goes I to the rag joint, the joint looks slight off in the direction I go when my wheel is straight in the highway. I think when it hit the hole and me gripping the wheel it skipped some splines on the shaft causing the wheel to be off center now .
    You can see the splines on the shaft.
    Still going to get an alignment tomorrow and I bet just adjusting the tie rods will all that is needed I hope. I'll update tomorrow afternoon.IMG_20230504_174446327.jpg
  19. May 4, 2023 at 4:49 PM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    If tie rods look ok and cams didnt budge I'm willing to bet your steering rack shifted. You can try to loosen the rack bolts, center your wheel then retorque them back down. Then go for an alignment if needed. These rack bolts tend to loosen up after while causing offset steering wheels especially after taking a turn or hitting something. It's a crappy design if you ask me with only 2 bolts holding it down. Older ones had 3 bolts.
  20. May 4, 2023 at 4:52 PM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Okay I'll look at those tomorrow. Thanks
    MA_TACO[QUOTED] likes this.
