Steering wheel play/ road wandering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PacoTheTacoMan, Aug 27, 2010.
  1. Aug 27, 2010 at 7:43 AM
    PacoTheTacoMan
    PacoTheTacoMan [OP] Well-Known Member
    Weathertechs, personally fabricated tailgate lock, tint, extra D rings, Exactfit seatcovers, re-enforcing the tailgate and adding a leaf next week.
    Let me start by saying that I have a 2010 reg cab manual 2wd. I have had it close to a year, and have noticed that I fight the wheel ever since I've owned it. Going down a smooth road at 55-60 mph, I am constantly correcting the wheel slightly. Alignment is good (haven't had it checked by professionals, but it tracks very well), tires are good with no bumps and at proper inflation. Tires are the Dunlops, BTW. I searched the forums, and have read of others having this issue, but haven't found any resolutions. Has anyone found a TSB that corrected this? I called Toyota, and the rep didn't know anything, but did get me hooked up with a case number for the leaf spring TSB. I would like to get all of this stuff done at one time. Thanks for any help.
  2. Aug 27, 2010 at 8:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Take the truck back to the dealer and have them check the allignment - under warrantee.
    If the allignment is within spec - then tell them to FIX THE PROBLEM.
    It's under warrantee...... get them to fix it!
  3. Aug 27, 2010 at 10:25 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I think the Tacomas are very sensitive to changes in the pavement. My 2009 drives perfect on some roads and on others the steering wheel shakes like I have a bad tire or something. I hope that doing the TSB for the rear springs helps. My truck seems light in the front because it gets loose when I get in the draft of a big rig.
  4. Aug 27, 2010 at 10:28 AM
    DevL
    DevL Well-Known Member
    There is a steering TSB... dont have the number handy, do a search and you will find it.
  5. Aug 27, 2010 at 10:54 AM
    PacoTheTacoMan
    Thanks, everyone, for the input.
