Steering Wheel resistance while pressing the brake?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DarthPow, Apr 13, 2021.
  1. Apr 15, 2021 at 4:43 AM
    Clearwater Bill
    Billy
    Largo Florida
  2. Apr 15, 2021 at 6:46 AM
    Waasheem
    Waasheem
    2007 xrunner
    We’ll also check the steering shaft ujoint as suggested early on. I’m wondering if larger wheels, larger contact patch could be part of the problem.
  3. Apr 15, 2021 at 8:02 AM
    DarthPow
    DarthPow [OP] Well-Known Member
    2012 DCLB TRD Sport 4x4
    when I release the brake and start rolling, and the steering can finally get to its end, it does make a slight high pitched whine kind of sound. It stops when I back off the steering wheel slightly... I thought this noise was fairly normal since its hitting the end of the travel in the steering system?
  4. Apr 15, 2021 at 12:10 PM
    Cattywampus
    Cattywampus Splitter of CV Boots
    Mark
    Colorado
    '03 Tacoma DC TRD OR
    It is normal to have this sound you describe at the end of travel of a perfectly functioning steering system. I take it the ptich doesn't change when you reach the hard spot in the travel?
    If so, I suspect a steering rack control valve problem (aka spool valve) or, as others have suggested, a bind point in your input shaft to the steering rack. To rule out the shaft, you could disconnect the input shaft at the steering rack and turn the wheel to see if you feel any bind here. Caution: Before disconnecting make match marks and put a loose bungee cord tied to the wheel and something else in the vehicle. The point of the bungee is so you'll know how many times you turned the wheel. This is important so you don't mess up your clocksprings.
  5. Apr 15, 2021 at 1:02 PM
    DarthPow
    cool, yea no sounds when I hit the sticking point. thanks for the tip, maybe we'll try that on saturday!
  6. Apr 17, 2021 at 6:00 PM
    DarthPow
    So @Waasheem graciously came out to look at my truck today, and we narrowed the problem down to worn suspension, specifically the LCA ball joints, which are really worn out.
    We sprayed them with some WD40, which seems to have alleviated the problem.
    I know it's a temp fix, but I'm hoping to rebuild my suspension soon, so I'll get it all fixed up properly then.
    b_r_o likes this.
  7. Apr 17, 2021 at 6:07 PM
    Clearwater Bill
    Billy
    Largo Florida
    If the LCA is that bad, it's dangerous.
    As in life threatening at any speed at all.
    For you, passengers and those around you, please repair before driving again.
    DarthPow[OP] and RedWings44 like this.
  8. Apr 17, 2021 at 6:50 PM
    Waasheem
    Waasheem
    2007 xrunner
    It is something that needs fixing. I don’t think we’re quite at life threatening worn. If ignored it would get there. It has a tiny amount of play, as in so tiny it’s difficult to see.
    Bandaide repair would be to take the cotter pin off, tighten the nut good, put a new cotter pin in (important step). Start shopping around to get it fixed. I have a couple places on my end of town but it’s a bit far.
    Just my opinion, again I’m no suspension steering expert.
  9. Apr 17, 2021 at 7:50 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    I don’t see what tightening the nut another turn would do if the slop is in the joint. If it was improperly torqued from the get go it could result in the tapered portion not fully seating.
    SR-71A likes this.
  10. Apr 17, 2021 at 8:05 PM
    DarthPow
    Im checking around to see what it takes to replace the ball joint myself. I have access to most tools, it's just a matter of finding the time, and if I feel like I'm capable of doing it properly.
  11. Apr 17, 2021 at 8:12 PM
    DarthPow
    I'm also a little lost as to why it was only binding when I'm stopped, and why it doesn't bind when I'm rolling.
  12. Apr 17, 2021 at 8:12 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    just rent a press. It’s pretty easy. Remove LCA from spindle which is 2 bolts, remove lower shock mount, loosen the LCA frame mounting bolts. At that point the LCA is free from the vehicle to have at it.
    Marc70 likes this.
