Steering wheel shake after balancing SCS wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjjencke, Nov 26, 2022.
  1. Nov 26, 2022 at 11:43 AM
    rjjencke
    rjjencke [OP] Well-Known Member
    Robbie
    Arizona
    '15 MGM DCSB OR 4x4 JBL
    I have a 2015 with 56k miles and I'm getting steering wheel shake at 50-60mph and can't figure this out.
    I recently swapped wheels to SCS Ray 10, but kept the same tires KO2's (285/65/16) with maybe 15k miles on them. I did not have this issue before the new wheels
    They (Discount) balanced the wheels upon installation, and I just took it back in to have them re-balanced twice in the last week and still have the same issue. They are using a road force balancer.
    They told me these wheels are difficult to balance because they have to start from the inside and move towards the outside and that I may still feel some light vibration. (Whatever that means!)
    Any thoughts on my next move? Go to another location? Look at something else? Thanks
  2. Nov 26, 2022 at 11:48 AM
    tcjacado
    tcjacado Well-Known Member
    Make sure the lug nuts are torqued to 85lbs
    More or less will also be a cause of this issue.
    Rambo MARINE Recon likes this.
  3. Nov 26, 2022 at 12:13 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Try to stay away from the chain stores to get an alignment. I would go to your typical mom and pop store/garage much better quality service.
    ToyoTaco25 likes this.
  4. Nov 26, 2022 at 12:39 PM
    rjjencke
    Robbie
    Arizona
    I would hope this is not the issue, as I’ve had them remove and balance 3 times now.
  5. Nov 26, 2022 at 12:40 PM
    rjjencke
    Robbie
    Arizona
    This is my next thought. But should it really be this difficult to balance some SCS wheels?
    tacomataco2 likes this.
  6. Nov 26, 2022 at 2:07 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If it wasn’t there prior to the new wheels, it’s a tire wheel issue. Have them rotate the tires 180 on the wheel, rebalance and test drive. Just because they’ve done three times doesn’t mean it’s correct. How much weight is on the fronts to get them to balance?
    VXEric, wi_taco and Hyperbarics like this.
  7. Nov 26, 2022 at 5:35 PM
    rjjencke
    Robbie
    Arizona
    I'm not positive how many weights they have one there. I do know I had them rotate the tires on the balance prior to the last one.
    Ok, so ask them to dismount the tires and turn them 180 and remount and balance? I would take them somewhere other then Discount I just don't know of any pros around here.
  8. Nov 26, 2022 at 6:04 PM
    Hyperbarics
    Hyperbarics Commercial Diver & Taco Driver
    Savannah, GA
    2013 DCSB - Nautical Blue Supremacist
    Yeah I second this. I do like discount tire, but they F'd my balancing up three times in a row. Tried to say the weights came off during travel.
  9. Nov 26, 2022 at 7:37 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Guy balancing them is a tard, go elsewhere, my buddy got his balanced with 39's no problem
    wi_taco likes this.
  10. Nov 27, 2022 at 12:24 PM
    gotoman1969
    Yes. Have them do one tire/wheel at a time. I used to work for DT and I was the trouble tire/wheel combo guy. Whenever I had an issue like yours first thing I’d do is 180 the combo and then even sometimes move them in 10-15 degree increments until I got the least amount of weight on them and they were balanced. The issue is more than likely there is a heavy spot in the combo matched up and no matter how much weight you put on and the machine says balanced. They spot at a certain speed will cause a vibration. Some places are/aren’t willing to putting in the time to balance truck tires correctly. Also sometimes you just get a crappy tire that no matter what you do just won’t balance and a good tech will replace it and start over. Good luck.
  11. Nov 27, 2022 at 12:44 PM
    Clearwater Bill
    Billy
    Largo Florida
    Because they have a Road Force machine doesn't mean the tech know's how to use it correctly. Or are willing to make the extra effort to do so.
    Many shops around here will charge extra to do a full on Road Force balance. Because it does take more time.
  12. Mar 23, 2023 at 5:07 PM
    rjjencke
    Robbie
    Arizona
    I just checked the front wheels, looks like there's about 20 weights per wheel. Is that bad?
    I'm still having the issue, I'm about to take it back and demand they rotate the tires 180 and re-balance. Anything else I should ask them?
  13. Mar 23, 2023 at 6:58 PM
    gotoman1969
    Yes. Make sure they road force balance them and that they use the correct adapter. They need to use the Haweka adapter.
  14. Mar 23, 2023 at 9:08 PM
    rjjencke
    Robbie
    Arizona
    Ok thanks. Does 20+ weights seem a little high?
  15. Mar 24, 2023 at 4:53 AM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Yes. That's about 2x what I would want to see. Like others have said, it's likely a mismatch between the wheel and the tire positions. This is pretty common when putting old tires on new wheels. The tire wears in based on the original wheel and when you mount it on something new, it is hard to balance. I always tell people if you're going to change wheels, get new tires too and just sell off the old combo.
    2WD likes this.
  16. Mar 24, 2023 at 6:33 AM
    gotoman1969
    If that’s tape weights that approx 6oz which is high.
  17. Mar 24, 2023 at 6:53 AM
    oneikr
    oneikr Well-Known Member
    2024 GMC Sierra 1500 Denali
    OP, a couple of years ago I tried putting some Raceline wheels on my VW Eos. They could't ever balance them correctly. I went back probably 7 times with no positive results. Discount even put new tires on thinking there may have been an issue with the tire. Tried hub centric rings which helped a bit but still not right. Finally, had to get new Enkei wheels which solved the problem. Discount tire was great and covered everything but in my case it was definitely the wheels. No way you should require that many weights on a wheel. Tons of folks on here have SCS wheels with no issues but you may have a wheel issue. Best of getting it figured out as I know how frustrating this is.
  18. Mar 24, 2023 at 8:42 AM
    rjjencke
    Robbie
    Arizona
    Just dropped it off. He agreed to rotate them 180 and re-balance. He said he’d also rotate the wheels and check for a bad tire.
    He did ‘remind me’ that these wheels are not ideal for balancing because of the offset being so deep.
    Also mentioned that if it’s still shaking after, it could be something else with the truck.
    VXEric likes this.
  19. Mar 24, 2023 at 11:02 AM
    gotoman1969
    What’s the offset?
  20. Mar 24, 2023 at 2:31 PM
    rjjencke
    Robbie
    Arizona
    -12mm Ray10 16x8
