Steering wheel shake after balancing SCS wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjjencke, Nov 26, 2022.
  1. Mar 24, 2023 at 3:35 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    -12 is not the issue. If they were -38 maybe.
  2. Mar 28, 2023 at 8:36 AM
    rjjencke
    rjjencke [OP] Well-Known Member
    Robbie
    Arizona
    '15 MGM DCSB OR 4x4 JBL
    So they rotated the tires 180 and re-balanced with road force ... same issue.
    One tech said 'if this doesn't work, it could be something else on the truck'. Another tech said 'if this doesn't work, we can try to get you into a different tire'.
    Is there something else I can look for? I'm tempted to ask for new tires, mine are certified.
  3. Mar 28, 2023 at 9:08 AM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    okay going to sound dumb, have them remove the tires, and "spin" the wheels on the balancer. I've seen a bent rim out of the box, I've also seen one wheel need a ton of weight. without the tires
  4. Mar 28, 2023 at 2:05 PM
    VXEric
    VXEric Well-Known Member
    Eric
    Worcester, PA
    07 ACS V6 6 Spd TRD Sport
    265/70/17 ATs on 17x8"wheels and 0 offset Morimoto XB LED Fogs Reinforced tailgate 2011 Honeycomb grille URD Short Shifter and cue- ball style knob
    Is there anyone local who can swap tires with you? Or do you have a full size spare? At this point you need to rule out something on the truck or isolate the issue to a specific wheel/tire combo.
    If I was in your shoes my next move would be meet up with a member, temporarily swap wheels/ tires and prove that the issue goes away. If it does, then just move two back over and see if it comes back until you are sure if it's the truck, a single wheel/tire combo or a single wheel/ tire.
