Steering wheel shake after new suspension and lift install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CP40, May 14, 2020.
  1. May 14, 2020 at 8:00 PM
    CP40
    CP40 [OP] Well-Known Member
    Toyota Tacoma TRD off-road 2020
    I put some 255/85 r16 ST Maxx tires on my 2020 Tacoma with only 5,000 mi on it. The tires pulled to the right hard but that was the only change.
    A day later I had a stage 3 icon suspension put in which included an alignment. The shop had to do the alignment twice.
    Driving away there was lots of shake in the steering wheel at highway speeds. The shake in the steering wheel seems to happen mostly at speeds above 50 miles an hour and going downhill. The steering wheel also seems to sit slightly to the left.
    What do you think is causing the shaking in the steering wheel?
  2. May 14, 2020 at 8:07 PM
    rkchkjhk
    rkchkjhk Member
    Nathan
    2020 White Tacoma TRD OR
    None....YET
    Just had my 5100's / 2888 OME coils put on today (2.5" front lift / 1.5" rear lift) with 285/70/17's put on today and everything went great ... except steering wheel wobble / shake on the highway trip back home. From what I've read its the needle bearing on the driver side. The fix is a bushing that replaces the Driver side CV axle needle bearing with bushing to help control Vibration and shaft float common on these differentials.
    Here is the part ... https://eastcoastgearsupply.com/i-8536125-toyota-8-clamshell-bushing-eliminates-needle-bearing.html
    Here is another thread ...
    https://www.tacomaworld.com/threads/ecgs-bushing-is-it-a-must.527875/
  3. May 14, 2020 at 8:20 PM
    CP40
    Be interesting to know if it fixes your problem. When do you plan on replacing it?
  4. May 14, 2020 at 8:25 PM
    rkchkjhk
    rkchkjhk Member
    Nathan
    None....YET
    Not sure, waiting to hear back from the shop that did my lift to get their opinion on cause and any other fixes.
  5. May 14, 2020 at 8:27 PM
    El Latigo
    El Latigo Well-Known Member
    Anaheim CA
    2017 MGM TRD OR Double Cab Short Bed
    I too have the ICON coil overs suspension lift, but everything was good from day one. I would start by making sure all nuts and bolts are tight to specs, then make sure the coil overs height was adjusted properly.. if all of that checks, have the tires balanced by a good tire shop..
  6. May 14, 2020 at 8:30 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    have a copy of the alignment specs?
  7. May 14, 2020 at 9:47 PM
    CP40
    Yes, I'll get you a picture of it tomorrow.
  8. May 14, 2020 at 9:48 PM
    CP40
    Let us know what happens. I'll tell you if I get mine resolved.
  9. May 14, 2020 at 9:52 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    This is BAD advice. The needle bearing issue results in a rhythmic pulsing vibration. It’s not going to make your steering wheel shake.
    OP your tires need to be balanced properly using a road force machine with the proper Toyota adapter.
  10. May 14, 2020 at 9:54 PM
    CP40
    Okay. But the tires were put on before the suspension lift and there was no shaking. Only when the new suspension and lift, with wheel spacers, was put on did the shaking start.
  11. May 14, 2020 at 9:56 PM
    fake4x4
    fake4x4 Well-Known Member
    Los Angeles, California
    3rd Gen Tacoma TRD Off-Road DCSB
    Cool stuff
    I’m guessing improper tire balancing with an alignment not ideal for a lifted Tacoma.. one more question, are your wheels just centric or lug centric ...
  12. May 14, 2020 at 9:58 PM
    CP40
    Don't know. The wheels are the stock wheels though.
  13. May 14, 2020 at 10:02 PM
    ProjectBangarang
    ProjectBangarang Well-Known Member
    Utah
    2020 Cement TRD Off-Road
    Total Chaos Bed Stiffeners C4 Bed Bars Smittybilt RTT Uptop Overland Bravo
    I thought I had read at some point that the needle bearing was not an issue for the 2020 and maybe 2019 because they changed out the part. I could be wrong though.
  14. May 14, 2020 at 11:10 PM
    Sharpish
    Brian
    are the spacers high quality hub centric? I bet that’s the problem.
    QuicksandTaco and Big tall dave like this.
  15. May 14, 2020 at 11:26 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Start with what you can do in your driveway first. Remove the wheel spacers see if it makes any difference. If not have the tires balanced again
    Curious what spacers did you use??
    Swapping out tires will not affect your alignment so you should not have been pulling hard in any direction.
  16. May 15, 2020 at 5:37 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Coopers are notorious for pulling to the right...
    Might be radial from tire conicity; and source of your vibes.
    Should have a road force balance with minimal road force weight applied using a Haweka adapter, or similar. It'll have a fitted collet for the hub bore and plate with tip adapters for securing.
    Brand of wheel spacers?
    Spacers and lug nuts tight?
  17. May 15, 2020 at 6:41 AM
    rkchkjhk
    rkchkjhk Member
    Nathan
    None....YET
    Got it. So my steering wheel wobble / shake is pretty rhythmic and only occurs at speeds >50 MPH. You believe its a tire balance issue and not a needle bearing issue? As I stated in my post, I'm on 285/70/17 KO2's with aftermarket wheels (17x9, 0 Offset). Thanks for the input!
  18. May 15, 2020 at 6:57 AM
    CP40
    I'm taking it back to the 4x4 place this morning. They're a well-known well-established southern California outfit.
    I'll pass along all the advice given and see if they can sort it out.
    I guess it could be a tire balance issue even though the car didn't vibrate when the tires were put on - it just pulled hard to the right. Lifting it may have exposed The tire imbalance even more.
    I don't know much about the spacers (except that they were "bolt on") but I'll check if they're hub centric as well.
    Thanks for all the advice. I'll report back when I know more.
  19. May 15, 2020 at 7:06 AM
    CP40
    I was thinking I just taking off the stickers on the right side, doubling them up on the left side and see if that straightens the car out.
    Greg.Brakes.Tacos likes this.
  20. May 15, 2020 at 7:24 AM
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Yup, you need about 1-1.5 degrees of cross caster (passenger more positive) to get coopers to drive straight.
    CP40[OP] likes this.
