steering wheel shake and rattle..
Discussion in '1st Gen. Tacomas (1995-2004)' started by 3.4PDM, Mar 30, 2010.
  1. Aug 18, 2010 at 9:05 PM
    #41
    shift96
    shift96 Well-Known Member
    That last pic makes my ass pucker:eek:
  2. Aug 18, 2010 at 9:18 PM
    #42
    01taquito
    01taquito "thats what she said"
    joe
    san antonio
    01 pre-runner sr5 quad-cab
    Bilsteins 5100's front and back. Wheelers add a leaf
    hells yeah. compare that pic with the one in the write up and it looks like a totally different truck. i was like "holy shit". but it did go back together. oh and im in san antonio so it was about 100 degrees:eek:
  3. Aug 19, 2010 at 6:46 AM
    #43
    route1286
    route1286 Member
    Rich
    California
    04 Tacoma Regular Cab
    Never ending...
    The last pic doesn't look all that different from my 04 regular cab when I did the fix. I pushed the wiring out of the way when I took my pictures (and took them from a slightly different angle).
    It's now been somewhere around 500 miles since I welded my slip joint and it still feels great. Did a couple of 4wd trails and some washboard roads this past weekend, and there was no rattle/clunking in the steering that it used to have.
  4. Aug 19, 2010 at 8:08 AM
    #44
    01taquito
    joe
    san antonio
    well i have driven mine for about 12 miles and it is different for sure. im still trying to figure out if its "better" though
  5. Aug 20, 2010 at 7:08 AM
    #45
    route1286
    route1286 Member
    Rich
    California
    Never ending...
    Yea, it took me a while to stop unconsciously correcting the direction of the truck on the highway, after living with the problem for so long. It's sort of like being used to old, bald tires, then getting new ones and trying to remind yourself not to compensate for bad tire performance.
  6. Aug 20, 2010 at 8:45 AM
    #46
    01taquito
    joe
    san antonio
    yeah im pretty sure thats exactly whats going on, but i sure am glad i finally did the work.
  7. Jan 8, 2012 at 7:18 AM
    #47
    ppleasants
    ppleasants Well-Known Member
    virginia
    05 TRD Sport Doublecab Longbed
    5100's set at 2.5", toytec AAL, DIY AUX port, broken mirror fix, temp/compass fix (twice), rattle-can gunmetal sport rims, debadged doors, fog-light anytime mod, DTRL mod, rear differential breather mod, drop in K&N air filter
    Does anyone know if this fix would work on a 2nd gen tacoma? I've been having the same trouble when I hit bumps or potholes in the road at about any speed. I thought maybe my bilstein 5100s were worn out from being overextended at 2.5" lift. Thanks for any input
  8. Mar 15, 2015 at 12:37 PM
    #48
    bentetzner
    bentetzner New Member
    2014 tacoma auto
    none
    Greetings,
    I am new to the list and drove my friend's new tacoma yesterday. I certainly verified his concern. It would be unacceptable if I owned this truck ! He only has 15,000 miles and has been to the dealer several times now with his concern !
    I am a retired mechanic, and I first looked at the flimsy connecting rod which goes from the rack to the steering column ! It is perhaps too thin and appears to have a u joint in it. If I had a hoist, I would certainly get under the vehicle and look at the complete suspension, but alas, I do not !
    Any suggestions would be appreciated because I think I will need to talk to the lame ass dealer mechanics, at some point.
    Ben
  9. Mar 15, 2015 at 12:50 PM
    #49
    roehoe72
    roehoe72 Well-Known Member
    Dan
    Vacaville, CA
    04 dc prerunner v6 trd
    I just fixed mine. Did not tack weld it. I elected to use a roll pin. Here is a link. But honestly research it more, because you don't need to take so much apart. Just the lower panel by your knees, clam shell around the column, two upper springs that are for your tilt, clamp bolt down at the firewall and two allen bolts. Btw this is for a first gen taco. What year is your friends? I will assume 2014 as per mileage statement.
  10. Oct 18, 2016 at 11:57 AM
    #50
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    anyone know what size roll pin to use if going that route?
  11. Oct 18, 2016 at 5:29 PM
    #51
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    It's not a safety concern... just an annoyance.
    The real safety concern is the proposed repair (fix).
    As welding or pinning that shaft can alter the shaft's compression
    during an impact or collision...
    Causing the steering shaft not to collapse promptly
    as it was engineered/designed to do.
    No biggie in my book... (I'm not fearful of the fix)
    But all the whiners looking for a free ride (repair)
    should be aware of how the fix can actually alter the shaft's function.
    Thus causing the repair to be even more dangerous to the driver's well being.
    Especially if the steering shaft does not collapse on impact /or collision...
    This repair (fix) could cause even more injury to the driver if done wrong.
    Because the repair can actually create more injury...
    the tack welds or pin size should be minimal (small)
    so that the shaft can still collapse/compress
    when an impact or collision might occur.
    I have done nothing to repair mine for 16 years...
    Even tho' I own a welder and have known the fix for some time.
    Just hasn't really been on my priority list.
    But it's good to know what the fault is...
    if or when I might wish to make the correction.
    Generally it just rattles a little and has a little steering slop.
    And tho' maybe annoying and not an ideal design...
    ...it will not fail.
    And so complaining to the NHTSA will net 1st gen Tacoma owners nothing.
  12. Oct 18, 2016 at 5:33 PM
    #52
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    I'll suggest the smallest diameter pin
    that you can drill a hole for.
    You want a high carbon pin that will shear (snap)
    rather then bend.
    You want the steering column shaft
    to collapse during impact or collision.
  13. Oct 18, 2016 at 7:27 PM
    #53
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    There is no single fix but heres what i would do, all new suspension bushings, mild shocks, P rated tires that are road forced balanced and have the proper pressure, steering rack bushings, and an alingment with correct caster. The will solve most issues.
  14. Jun 6, 2019 at 7:55 PM
    #54
    D60
    D60 Well-Known Member
    So I know this thread has been going on forever and I just wanted to thank anyone who has contributed with useful info. I did this on an '02 Taco today and it certainly helped.
    I used the "easy" method of just pulling the clamshell directly behind the steering wheel, the 4 electrical plugs directly under the wheel, the 12mm bolt at the firewall and the two 6mm hex bolts at the pivot. And of course the tilt springs. I found the springs to be the biggest challenge, I finally used some random small pieces of 2x4" as a fulcrum against the dash to lever my needle nose vise grips which were locked onto the spring(s). I'd also reco a headlamp so you can really see what you're doing with the springs.
    Still, others are right that you can get it all out in ~15 minutes, provided you don't spend too long fighting the springs.
    I'm a metalworker by trade so tacking it was no problem
