steering wheel shake brake problem
Discussion in 'Technical Chat' started by OhYeah, Mar 3, 2014.
  1. Mar 3, 2014 at 4:09 PM
    OhYeah
    OhYeah [OP] Well-Known Member
    so cal
    2006 DCSB
    Hey guys, so about a year ago, My steeting wheel was shaking pretty significantly at freeway speeds during braking. I replaced the rotors and pads and it was fine until now. The shakes are back with a vengeance!! I dont drive in a lot of traffic and I would say I drive conservatively. No off roading or any wheel upgrades. What could be causing this?? I hate this problem! Makes both my arms shake with the wheel when I brake!:confused:
  2. Mar 3, 2014 at 4:17 PM
    OhYeah
    so cal
    2006 DCSB
    I used brembo blank rotors and hawk LTS pads when I replaced. Also, Im not sure if the rear brakes can cause this problem but, like I said before, the problem went away for a bit when I changed the parts.
  3. Mar 3, 2014 at 4:24 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Sounds like time for new rotors and pads. Rears won't cause your steering wheel to shake. How many miles on calipers? May need rebuilding.
  4. Mar 3, 2014 at 4:32 PM
    OhYeah
    so cal
    2006 DCSB
    But I just replaced both.. the truck has 96k miles on it.
  5. Mar 3, 2014 at 6:21 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    What year taco? Have you had the front wheels off? I've been told if front wheels are not torqued per spec it can warp rotors.
  6. Mar 3, 2014 at 6:26 PM
    OhYeah
    so cal
    2006 DCSB
    2006. I always use a torque wrench to tighten the wheels.
  7. Mar 4, 2014 at 8:13 AM
    na8rboy
    WI
    Sometimes you just get a bad set, or could be braking habits. I found it's just best to stay with OEM when it comes to brakes. Check to see if Brembo will warranty them.
  8. Mar 4, 2014 at 9:38 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    You didn't mention having a pull, but there's a few things that will warp the rotor:
    1) Machining them will remove material making them heat quicker. Obviously not the issue as they were new.
    2) A caliper dragging. When you replaced the pads, did the calipers retract easily? Did you clean and lube the sliding points?
    3) Overtightening the lug nuts. Did you torque them with a wrench and not the air gun?
    4) Cheap steel on the new rotors. Shouldn't be an issue with Brembo's.
    My guess is a caliper is starting to drag. Easy way to check is to carefully feel the wheels after you get out of the truck to see if one side is noticeably hotter.
  9. Mar 5, 2014 at 12:20 PM
    OhYeah
    so cal
    2006 DCSB
    So, if it's the caliper? What needs to be done? Will a shop rebuild it? Do I need new ones?
  10. Mar 5, 2014 at 12:42 PM
    na8rboy
    WI
    A good shop can rebuild it. I wouldn't trust some Wal-mart style shop. Rebuild is pretty simple, disassemble, clean hone bores polish pistons, new seals. If you go new I would stay with OEM. I have had problem with none OEM on Toyota's.
    To check if you have bad caliper, jack truck and spin wheel. Apply brakes and spin wheel again, to see if releasing properly. Also while you are driving and apply brakes truck will usually pull to one side or other.
  11. Mar 5, 2014 at 5:54 PM
    OhYeah
    so cal
    2006 DCSB
    Thanks! No noticeable pull to either side. But its hard to say when the steerimg wheel is shaking my arms off.
