Steering Wheel Shake??
Discussion in 'Wheels & Tires' started by Taco Vender, Dec 23, 2010.
  1. Dec 23, 2010 at 4:20 PM
    Taco Vender
    Taco Vender [OP] Active Member
    Mark
    Huntington Beach, CA
    06 white PreRunner
    Tonneau Cover, spray painted stock rims.
    Hey everyone,
    Just got new 265/75/16 toyo all terrain open country, for my 2006 access cab tacoma. I got them balanced and all set up. But i recently noticed when I drive on the freeway at about 60-70 my steering wheel starts to shake.
    any thoughts, it is really annoying on long distance drives?
  2. Dec 23, 2010 at 4:22 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    go back in where you got the tires and have them rebalanced...I had the exact same problem when I got new tires the other day. After getting them rebalanced it rides great.
  3. Dec 23, 2010 at 4:23 PM
    05TacomaCO
    05TacomaCO mmmmm beer!
    Paul
    Pueblo West, CO
    05 4x4 Access Cab
    Afe Filter, 5100s, AAL, Avid Sliders, All Pro plate bumper, fog light mod, blacked out tails, blacked out bumper, hose clamp tailgate mod, BHLM, 285/75/16
  4. Dec 23, 2010 at 4:27 PM
    Taco Vender
    Mark
    06 white PreRunner
    Thanks, ill go tomorrow and see if they are open. "offroadtoy" what tires did you buy?
  5. Dec 23, 2010 at 4:45 PM
    OffroadToy
    4X4 Offroad
    I got BFG a/t ko's in 265/75/16 from Costco. I took it down the highway the next day and noticed the steering wheel shake at around 60 mph. Took it back and had them rebalanced...made a heck of a difference!:)
  6. Dec 23, 2010 at 10:19 PM
    Taco Vender
    Mark
    06 white PreRunner
    Nice! i was going to get those, let me know how they work off road and snow.
  7. Dec 23, 2010 at 10:54 PM
    shocker01
    shocker01 Well-Known Member
    Gordon
    Ky
    01 Tacoma 4x4 TRD
    5100 Billies, drop-in k&n, deck plate, gray wire, Dynomax exhaust.
    Had the same problem with a set of at/ko's, after I had them road force balanced they were smooth perfect.
  8. Feb 2, 2013 at 9:03 AM
    robjobu74
    robjobu74 Member
    CA
    08 PreRunner TRD Sport
    After hours of researching this issue seems a lot of you are experiencing this and there dosent seem to be a real fix. Well here it is.
    Tacoma's are called hub centric. That means they balance at the hub and not the lug. Now the easy fix to some of your issues are to have your tires balanced. If that dosent work or the problem comes back then the issue is at the hub.
    If you have spacers as I do then they need to be hub centric meaning they need to have a small lip on the spacer that the rim will balance on. If you have after market rims then the bore size of the rim might be larger then the factory hub, which is 106. So if the aftermarket rim is larger it will wobble and your steering wheel will shake. You need to get centric rings to make the rim fit tightly to the hub.
