Steering wheel shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgrande, Apr 21, 2011.
  1. Apr 21, 2011 at 9:41 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    I made some videos of whats going on with my steering wheel. Its been going on for a a while now. I have had my tires balanced (twice actually) hoping that would solve the problem but it hasnt. I did accidentally go 10k miles without rotating them. That was taken care of last Saturday however. The shaking only happens between 45mph and 65mph.
    http://www.vimeo.com/22729202
  2. Apr 21, 2011 at 9:44 PM
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    That's funny, mine just did the same thing for the first time the other day.
  3. Apr 21, 2011 at 10:10 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    ypu wouldnt happen to have mud or anything packed on the inside of your wheels do ya?
  4. Apr 21, 2011 at 10:15 PM
    plee33
    plee33 Well-Known Member
    Peter
    Sacramento, CA.
    SWB TRD Sport Long Bed 4x4
    SnugTop SuperSport Shell, BedRug, OME Heavy Duty Lift Kit, Weathertech Liners, more to come....
    Bad Tires. Did you check the tread wear? My Camry and Tacoma had the same problem, all because of uneven tire wear. Check for saw-toothed wear pattern.
  5. Apr 21, 2011 at 10:15 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    I had the wheel shake when I first got my truck. I just put the 5100's on it at .85 up front and replaced the rear with 5100's as well. The has practically gone away, and I haven't gotten the tires balanced or the alignment done yet...
  6. Apr 21, 2011 at 10:19 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    I dont know if this is gonna be much help, as a matter of fact, I know its not any help...LOL...But this happens alot with the FJs, steering wheel shake which gets really bad with higher rated tires [i.e more plies]. Ive had the issue on my FJ for a while and Ive had them road forced about 4-5 times in the last 3 months and Ive never been able to get rid of it, only minimize it. Ive heard its just the delicateness of Toyota suspension but it all seems to be random explanation for a mysterious issue that no one can solve. In any case, check for mud like someone else mention, and maybe get them roadforced. Ive gone through about 10 tires on this FJ so tires are good, its def my vehicle. Good luck
  7. Apr 21, 2011 at 10:20 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    theres a good chance that I have mud everywhere...
  8. Apr 21, 2011 at 10:21 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    Thats another explanation someone has thrown out there as well, that is upgrading the suspension. Not sure how much itll work but if it works then cool. I plan on upgrading my FJ down the road so Im sure itll go away. For now though, Ive minimized it alot and kinda just forgot about it. Every now and then Ill think about it while im on the fwy and I get angry and frustrated, but then I forgot about it and the sun comes out and flowers bloom again.
  9. Apr 21, 2011 at 10:23 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    well my tires are in good shape, have at least 25k left in them. I did go a while with out rotating them though.
  10. Apr 21, 2011 at 10:24 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    I have a full ome suspension and the problem is only recent compared to when I put the lift/tires on
  11. Apr 21, 2011 at 10:25 PM
    plee33
    Peter
    Sacramento, CA.
    Did you check for saw-toothed wear patterns.
  12. Apr 21, 2011 at 10:27 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
  13. Apr 21, 2011 at 10:28 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    yeah, there doesnt appear to be any at all. That would be toe right? Would that be something that could cause this?
  14. Apr 21, 2011 at 10:31 PM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Well when I watched the video of you slowing down I thought you rotors might be warped but it does it when your accelerating so I don't think it could be that though.
  15. Apr 21, 2011 at 10:31 PM
    plee33
    Peter
    Sacramento, CA.
    My Camry had saw-toothed wear and caused steering to shake. The reason behind it...bad struts. Your truck is too new for that kind of stuff. You need new tires. Steering shake discontinued after new tires on both my cars.
  16. Apr 21, 2011 at 10:43 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    yeah I thought about that too since I'm getting close on them but its not only when braking.
    plee33, I'm not dropping $1200 on new tires there has to be a fix for this.
  17. Apr 21, 2011 at 10:50 PM
    Fienoma
    Fienoma Well-Known Member
    Hieu
    New Mexcio
    2007 double cab Off road 4x4
    BHLM, In bed lights mod, K&N intake,OEM bed extender....more to come?
    i have the same issue as you..i can't explain whats causing it either.. it only happened after i lifted my truck to 2.5 billys and a AAL in the back and upgraded to 285's. My tires are brand new, balanced and just rotated at 5k.
    Edit: I also have no mud even near my truck..and never have been in mud.
  18. Apr 21, 2011 at 10:50 PM
    plee33
    Peter
    Sacramento, CA.
    The shaking is just going to continue to get more worst. It's gotta be your tires and you need to replace them. You can try to re-balance. Worst case, wheel bearing. From looking at your second video, this shake is really bad because it already begins to shake at 45.
  19. Apr 22, 2011 at 7:37 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
    I too was having steering wheel shake above 45mph & was told it was my stock crappy Dunlop tires. Yesterday I bought new Michelin tires. The tire shop discovered out of round stock rim which was on the right front. I now know why the wheel shake was not so bad at times because the tires were rotated every 5k miles. They balanced that tire as well as possible & put it on the back. My steering wheel shake went away, but now have driveline vibration. I will be replacing the tweaked rim very soon.
  20. Apr 22, 2011 at 7:57 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    where are you getting them balanced at?
