Steering wheel shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MSgtUSMC, Apr 28, 2009.
  1. Apr 28, 2009 at 6:23 AM
    MSgtUSMC
    MSgtUSMC [OP] Active Member
    Oro Valley, Arizona
    2017 Tacoma TRD 4x4 Off Road
    Icon Stage 1 lift, Tuff Country 2" AAL, 285/70/17 KO2s, 17" KB black wheels, Rough Countey 30" LED.
    :confused:Installed my 5100s this past weekend, I am getting a serious shake at the steering wheel, when I take my hands off the wheel you can see it shaking back and forth. Alignment done, either my tires need balanced or can you get drive shaft vibration all the way to the wheel. It seems to be the worst between 45 and 60 mph. Any suggestions or ideas to stop this.
  2. Apr 28, 2009 at 6:49 AM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    I would make sure you torqued all of the wheels down the same, have all of the lugs tight, and check the balance on your wheels.
    If you rotate them to the back and find the vibration in the rear then it is def. your tires, so you would need to get them balanced.
  3. Apr 28, 2009 at 6:58 AM
    Krp2nite
    Krp2nite Well-Known Member
    Mine was doing the same thing. Got the wheels balanced and all 4 were out of balance. Had them rotated too. Gone now.
    It doesn't cost anything since I bought the tires at pepboys, so since they are mud tires anyway the guy said they could check the balance at each tire rotation.
  4. Apr 28, 2009 at 7:05 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    I was running MT tires and had a death shake in my steering. I have the tire rebalance but it didn't fix the shake.
    I went back to my stock wheels and when I pulled my driver wheel I found I had dried mud in all the vents of my brake rotor, I clean it and put my stocks back on and I don't have the death shake anymore.
    I think it was either the dried mud in the rotor or that one of my MT tires is out of round.
  5. Apr 28, 2009 at 8:06 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Most likely the dried mud.... Anything stuck in/on the wheels can cause an out-of-balance condition.
    Did you ever put the MT's back on?
  6. Apr 28, 2009 at 8:10 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    No not yet, they were killing my MPG's. I will put them back on in a few weeks.
