Steering wheel shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Healyj7, Apr 17, 2017.
  1. Apr 17, 2017 at 3:13 PM
    Healyj7
    Healyj7 [OP] 2010TRD Cape Cod
    Cape cod MA
    2010 Tacoma 4x4 crew cab...
    Led third brake light All bulbs changed to LED Blue... Bed cover Extra tie downs in bed Borla 3' aftermarket excuast Blacked out front grill Smoked front lights White turn/running lights Bed security Mod 2 inch front lift and level with bilstein front and rear shocks... 1 Inch wheel spacers BF Goodrich AT tires 270/75/17
    I have a 2010 TRD sport with leveling kit installed and a little bigger tire on stock rims. I am experiencing shaking in my steering wheel!!! What is the possible cause and fix?
  2. Apr 17, 2017 at 3:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    # 1 thing to do is be sure the front tires are properly balanced.
    Easy test is to rotate the fronts to the rear and see if the shake moves.
    wilcam47 likes this.
  3. Apr 17, 2017 at 3:55 PM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    Dirt buildup or a weight was thrown comes to mind
  4. Apr 17, 2017 at 3:56 PM
    Healyj7
    Cape cod MA
    Will check that out, does not pull side to side just shakes so that might be the issue will put it on the lift tomorrow and check it out and rotate tires
  5. Apr 17, 2017 at 3:58 PM
    CroTaco
    CroTaco Well-Known Member
    Tulsa OK
    2007 White Tacoma PreRunner TRD package
    3 inch lift.
    What speeds do you get a vibration? Balance is usually a high speed vibration not low speed.
  6. Apr 17, 2017 at 4:05 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Is it during braking? Also how many miles on the tires?
  7. Apr 17, 2017 at 4:30 PM
    Healyj7
    Cape cod MA
    New BF Goodrich AT about a month old it happens about 20-40 mile per hour and when breaking
  8. Apr 17, 2017 at 4:34 PM
    wilcam47
    Will
    Bourbon state
    might check your brake pads/rotors and wheel balance.
  9. Apr 17, 2017 at 4:48 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Might retorque your wheels, the tire shop probably cranked them down with an impact and warped the rotor. 90ft/lbs is factory spec. I had a 2015 that constantly had steering wheel shake at 55-65mph. 2 sets of tires, road force balancing, front end alignment and never could get rid of it.
    hueman562 likes this.
  10. Apr 18, 2017 at 2:49 PM
    CroTaco
    Tulsa OK
    3 inch lift.
    20-40 mph won't be balance, if it's when braking, it's most likely the brakes. Do you feel shake in pedal, steering wheel or seat?
  11. Apr 18, 2017 at 3:04 PM
    gonathan85
    gonathan85 Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    Start with simplest things first...check tire pressure.
  12. Apr 18, 2017 at 3:27 PM
    Clearwater Bill
    Billy
    Largo Florida
    Kyitty likes this.
  13. Apr 18, 2017 at 5:40 PM
    TRD Beast 916
    TRD Beast 916 Well-Known Member
    Tommy
    NorCal Sacramento
    2014 Toyota Tacoma TRD Sport
    New pads and rotors will do the trick
  14. Apr 24, 2017 at 6:59 PM
    LiLRay808
    LiLRay808 Member
    Oahu
    2013 Taco
    Ever figure out the problem with your truck?
  15. Apr 24, 2017 at 7:02 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    That's also the specific speed range the Needle Bearing causes vibrations asnd grinding in 4x4 Tacomas. But that's not in the steering wheel.
    I'd say poor tire balance or alignment issue.
  16. Apr 24, 2017 at 7:08 PM
    LiLRay808
    LiLRay808 Member
    Oahu
    2013 Taco
    Rebalanced and re aligned multiple times already and still no change. Only stopped for the most part after I put my stocks back on
  17. Apr 24, 2017 at 7:51 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    Road Force Balancing is required. Traditional balancing doesn't always work on Tacomas.
  18. Apr 25, 2017 at 3:34 AM
    TACO TX
    Kelly
    Denison ,Texas
    No, it never went away. I would go days with no vibe or shake and then just out of the blue they would return.would
  19. Apr 25, 2017 at 3:46 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Keep it stock and it rides as smooth as butter. 133,000 miles on mine and she rides like it's her first day ever on the road...
    ChadsPride likes this.
  20. Apr 25, 2017 at 6:30 AM
    justdoit
    Colorado Springs
    Is that before or after the rear bottoms out on the bump stop o_O
