Steering wheel shake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Zach O, Oct 8, 2017.
  1. Jun 3, 2018 at 9:34 AM
    #41
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    I think I'll go ahead and give these a try :fingerscrossed: https://www.amazon.com/dp/B0032HQJ7G
    fs007 and EatSleepTacos[QUOTED] like this.
  2. Aug 28, 2018 at 6:47 PM
    #42
    fs007
    fs007 Well-Known Member
    06 AC 4x4 4cyl
    did this end up working for you? Im running into the same issue now...problems and symptoms described in the original post...It started after a 14000 mile cross country trip and ironically only became noticeable when I removed the rack and rtt from the bed. I thought it might be the aftermarket wheels and tires so I swapped them to the originals I had laying around...still shook/shackes...I thought it was my front brakes initially as I found that one of my calipers wouldn't "open all the way back up anymore"...so with the whole front brake system replaced (rotor pads calipers) and the shake still there im looking to diagnose...
  3. Aug 28, 2018 at 7:37 PM
    #43
    BraskaTaco
    Midwest
    2013 Tacoma TRD OR
    The rings seemed to have helped the vibrations slightly but they are still there at around 60 mph. Definitely a little better though.
  4. Aug 29, 2018 at 2:50 AM
    #44
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    As crazy as this sounds, look at your drum brakes. There should be little weights on them and you might've slung one off. One guy on here had vibes and a new drum solved it for him. I remember you had issues with your e brakes so maybe it's linked.
    Biscuits, fs007[QUOTED] and DrFunker like this.
  5. Aug 29, 2018 at 2:53 AM
    #45
    DrFunker
    DrFunker Well-Known Member
    You are like Click & Clack. :bowdown:
  6. Aug 29, 2018 at 2:59 AM
    #46
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Jack of all trades and master of none :D
    Alexely999 and DrFunker[QUOTED] like this.
  7. Aug 29, 2018 at 3:02 AM
    #47
    DrFunker
    Don't be so hard on yourself Jack.
    EatSleepTacos[QUOTED] likes this.
  8. Aug 29, 2018 at 4:54 AM
    #48
    fs007
    06 AC 4x4 4cyl
    Just pulled the the rear brakes apart...besides them needing to be replaced and the parking brake fixed I found everything to be wet with grease when I opened the left rear brake...the seal in there seems to have gone bad and some of the grease is coming out into the drum...I guess I will replace that and the brakes and see if that does anything...I would be amazed if a rear brake issue could shake my steering wheel the way it does when it vibrates and wobbles...days of owning a lifted Xterra would have told me it was something in the front end but I guess I will see :/
  9. Sep 27, 2018 at 7:46 PM
    #49
    chuymoreno
    chuymoreno Well-Known Member
    El Paso, Texas
    Tacoma SR5
    Did doing this resolve your problem?
    I’m having the same issue!
    fs007[QUOTED] likes this.
  10. Sep 27, 2018 at 7:59 PM
    #50
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    Have someone balance the tires while you watch. If they are using a decent balancer and they have to add weight part way around after the first balance you have a bad tire where the belts are shifting inside the tire. The only answer is a new tire/s otherwise you have a wheel bearing that is going out.
  11. Sep 28, 2018 at 6:58 AM
    #51
    fs007
    06 AC 4x4 4cyl
    YES! Sorry totally forgot about this thread! I had the seal replaced on that side of the axle and put new brake shoes and hardware in...I have no noticeable shake whatsoever...I actually cleaned the oil and grease off the brakes when I initially found out the seal was leaking and that already reduced the wobble...now that everything is dry and the shoes are new it rides buttery smooth (for how long remains to be seen :/
    PzTank likes this.
  12. Sep 28, 2018 at 8:00 AM
    #52
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    Its funny you say this was the fix. I just got an 09 tacoma about two months ago. The other day I noticed a shake in the wheel at about 60 mph. Shortly after it stopped, and then I hit a stoplight. I could smell brakes. Haven't smelled them or experenced wobble since. I'll have to check this to see if I've found the culprit.
  13. Sep 28, 2018 at 8:05 AM
    #53
    fs007
    06 AC 4x4 4cyl
    So the other thing that I would check if I were you would be your front calipers....depending on how high milage your truck is they may need to be replaced...my truck (189,xxxmiles now) had an issue where my front calipers wouldn't open all the way back up on occasion...something about the pistons in the calipers...that would also create an issue on occasion where the truck would pull one direction or another....have all new hardware in the front now and don't have that issue anymore....calipers aint cheap though...
    weeksz[QUOTED] likes this.
  14. Oct 27, 2018 at 4:31 PM
    #54
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    Disregard.
