Steering wheel shake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rokstarwannabe, Nov 30, 2017.
  1. Nov 30, 2017 at 3:00 PM
    rokstarwannabe
    rokstarwannabe [OP] New Member
    Roger
    Langley BC, Canada
    2016 Tacoma TRD sport
    levelling kit, 275/70/17 BF Goodrich KO2 tires,
    I've poured through this forum regarding my steering wheel shake and can't come up with where to start with this. The Toyota dealer employs Captain Obvious I'm pretty sure cuz they were no help on the phone so I'll see if any of you guys have the same issue.
    I have a 2016 Tacoma Sport with 45,000 kms on it. I just went to Kal Tire and had 275/70/17 BF Goodrich KO2 tires mounted to replace the shitty 265/65/17 stock tires and also had a 2" levelling kit installed. I had to also install a ¼" spacer on the front wheels to avoid rubbing.
    The truck drove like a dream before but now shakes and vibrates at 80-95 kph, but only sometimes. I've read about the steering rack bushing upgrade but I'm not sure if that's for the 3rd generation Tacos. I've also heard about the adaptor for wheel balancing Tacoma wheels of which the dealer had never heard of.
    Any feedback will be greatly appreciated.
  2. Nov 30, 2017 at 3:10 PM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    Seems to me your new tires needs to be balanced again. I'd take it back to where they were installed and tell them to recheck the balance and also the install of all the components.
    TACO TX likes this.
  3. Nov 30, 2017 at 3:15 PM
    HMBTaco
    HMBTaco Active Member
    Adam
    Bay Area, California
    2017 TRDOFDC M/T -----> 2018 TRDOFDCLB
    Kings, Camburg, SCS .... The usual
    I've had 1 K02 that was out of round by a good amount, so much so that it would never balance, had 3 separate shops balance them before I looked into it myself and relized it was out if round. Jack the the truck so the tire is half an inch off the ground or so and rotate by hand, listen for the tire coming into contact with the ground at all
  4. Nov 30, 2017 at 3:16 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Ko2s can be sometimes hard to balance, I steering shakes a little at 50-55mph, I thought it was my lift but im going to try road force balancing tires next.
  5. Nov 30, 2017 at 3:17 PM
    HMBTaco
    Adam
    Also the 1/4 spacers can be giving you a problem as we'll, could be something between the spacer/hub, spacer/wheel causing it
  6. Nov 30, 2017 at 5:46 PM
    mastro1
    mastro1 Well-Known Member
    2017 MGM DCSB TRD Sport
    Did you get the tires and leveling kit done at the same time? Or did you start feeling this right after the tires? FYI.. I have mounted and balanced brand new tires and the the road force was to high, wouldn't balance. the balancer would show "0" as if it was balanced, but when you drive the ride quality sucked! had to get new tires! sent them back to the manufacturer. Go back to how put the tires on!
    f
  7. Nov 30, 2017 at 5:55 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Stock wheels?
    Spacers are hub-centric?
    Everything torqued correctly?
    Can you post alignment numbers?
  8. Nov 30, 2017 at 6:02 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Also check lugs for proper torque, some tire shops just use an impact and crank them down instead of spec.
  9. Nov 30, 2017 at 6:03 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Take the 1/4" spacers off, you probably have nothing centering the wheel on the hub. If that is not an option you will have to go with BORA or Spidertrax spacers. I think BORA has Tacoma 3/4" hub centric spacers.
    America's Tire, is the only place I have balance my tires. KbrO2's can be hard to get right if you are a lazy tech.
    rokstarwannabe[OP] likes this.
