Steering wheel shake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by imjohn, Jun 9, 2019.
  1. Jun 9, 2019 at 2:31 PM
    imjohn
    imjohn [OP] Well-Known Member
    I have recently installed bilstein 5100 and HS AAL in the rear on my truck. I also added 33in falken wildpeak tires and scs Ray 10 wheels. I’ve been driving it for quite some time now and when it gets to around 45mph, the steering wheel would start to shake a lot rapidly. I’ve had it balanced 3 times already from 2 different discount tires and still no luck. Any idea?
  2. Jun 9, 2019 at 2:36 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Need more info, miles on truck, alinement numbers, etc etc
  3. Jun 9, 2019 at 2:54 PM
    imjohn
    Sorry about that. 2017 Tacoma TRD Off-road. About 20k on the truck. I currently don’t have the alignment numbers on me but I got it done at pep boys.
  4. Jun 9, 2019 at 3:03 PM
    NYCTaco52
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Could be a few things.
    Either your alinement place isn’t doing it good
    Your wheel bearings are going out (which is possible at that milage, just not likely)
    Your tires are out of round, sometimes it happens from the factory
    Or something might have worked itself loose over time after the lift.
    Try rotating your tires first, it’s free and will get that option out the way
    wilcam47 likes this.
  5. Jun 9, 2019 at 3:43 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Warped front brake rotor(s) check the run out
  6. Jun 9, 2019 at 3:47 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Wat?
  7. Jun 9, 2019 at 3:47 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I also vote to rotate and see if the issue moves around.
  8. Jun 9, 2019 at 4:18 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Rotating tires should always be the first move in something like this. It will rule out the cause being the tires or the truck
  9. Jun 9, 2019 at 5:06 PM
    imjohn
    I’ve gotten it rotated twice already aswell. Same outcome.
  10. Jun 9, 2019 at 5:29 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Didju ever do ECGS?
  11. Jun 9, 2019 at 5:44 PM
    imjohn
    No I haven’t.
  12. Jun 9, 2019 at 6:38 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Didju try the 4wd elimination method. This might very well be it.
  13. Jun 9, 2019 at 6:46 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Could be the drive shaft. Did you add any angled shims to the rear springs? Carrier bearing drop? It only does it at 45 MPH? Vibration goes away at 55-60 MPH?
  14. Jun 9, 2019 at 6:48 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    True ^^. I'd say, replicate the vibration, try 4hi while driving straight, if vibration goes away it's the needle bearing, if not, it might be pinion angle
  15. Jun 9, 2019 at 7:09 PM
    imjohn
    It continues on when I increase speed. It doesn’t go away unless I’m at under 40.
  16. Jun 9, 2019 at 7:39 PM
    imjohn
    So I tried it on 4hi and no vibrations what so ever. I swapped it back to 2wd and it had no vibrations for a while and then it came back when I going around 65mph. My guess is it’s the needle bearing that you mentioned.
    Skydvrr[QUOTED] likes this.
  17. Jun 9, 2019 at 7:45 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    ECGS ftw. Search the forum. Plenty of install info parts list etc
    imjohn[QUOTED][OP] likes this.
  18. Jun 9, 2019 at 8:46 PM
    imjohn
    Thank you. I really appreciate the help and everyone else.
  19. Jun 9, 2019 at 8:58 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That's why (most of us) are here!
