steering wheel shakeing.
Discussion in 'Wheels & Tires' started by cgarano, Jun 27, 2009.
  1. Jun 27, 2009 at 2:41 PM
    cgarano
    cgarano [OP] New Member
    Las Vegas
    09 dbl cab v6 4x4
    Hello, Just bought a new 09 Tacoma v6 4X4 Dbl cab short bed and I am experiencing steering wheel shake above 60 mph, took it to the dealer they realighned and rebalenced the tires and its still doing it, they dealer is telling me it's normal. Is any one else experiencing this problem? thanks for your help.
  2. Jun 27, 2009 at 4:00 PM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    no it should not shake, how can that be normal. I can't believe you accepted that for an answer.
  3. Jun 30, 2009 at 10:52 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    I've got a similar truck to yours, except mines a prerunner. Just got my recently too, and have had no such problems. I would definitely go back and bitch up a storm,
  4. Jun 30, 2009 at 11:49 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    It should not shake! Dont accept that for an answer! If they really checked the tires for balance, then you may want to try and rotate your tires. One of my BFGs will make my steering shake slightly when its on the front, but when its on the rear my truck rides buttery smooth and no shake(its not balance for me; no rocks in the tread, perfectly balanced tire/wheel and it does it). I've heard once in a while that some tires just tend do that. Might be that they barely passed mfg's inspection or something, idk for sure.
  5. Jul 28, 2009 at 8:27 PM
    keystoneclassic
    keystoneclassic New Member
    Gilbert, AZ
    08 Prerunner SR5 Double Cab Long Bed
    A friend of mine that is a salesperson for Toyota said that they are having a ton of issues with the tires flat spotting on the cars/trucks they sell are selling because they have been sitting on the lot for so long. I'd request that they replace your tires and/or have then road force your current ones. I had to go back 3 times before they road forced mine and then the shimmy went away.
  6. Jul 28, 2009 at 8:51 PM
    WV_Tacoma
    WV_Tacoma Well-Known Member
    Huntington, WV
    05 Pre, DBL Cab
    Not enough
    The flat spot thing could be a real issue.............
    The toyota's have lug centric wheels.......Mine shock slightly when new. Changed the wheels and they shake like the front end was going to fall off......
    I have to remove the wheels, hand snug each nut rotating the wheel 180 degrees to get the nut top dead center( this lets the wheel fall in to the tapered slot better) ONLY hand tighten, then use the socket hand tighten rotating same way........LOL don't laugh if I don't do this the thing shakes all over.....Then just use the weight of the socket and wrench, then torque the nuts.... Some times I have to re-do it.....
    I road balanced, road wayed, drove, slide and took the tires back and still have the same deal....
    But don't you dare let them off the hook!!
    GOod luck
  7. Jul 28, 2009 at 10:14 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    :wave: Howdy neighbor. This is not normal.Don't buy that bs.Which dealer are you going to?? Findly has been treating me good so far.:cool:
