Steering wheel shakes if I am slowing down from highway speeds without pressure on steering wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Falcoholic87, Apr 23, 2023.
  1. Apr 23, 2023 at 5:23 AM
    Falcoholic87
    Falcoholic87 [OP] Active Member
    2005 Tacoma
    05 Tacoma Base
    This hasn't been a big problem for me just something I notice from time to time...I'm assuming I will need new shocks. But if I'm loosely gripping the steering wheel it will shake as I'm slowing down from highway speeds.
    Am I correct in assuming I will need new shocks?
  2. Apr 23, 2023 at 5:25 AM
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    I’d have the brakes checked.
    12TRDTacoma and Rocketball like this.
  3. Apr 23, 2023 at 5:28 AM
    Falcoholic87
    2005 Tacoma
    New brake pads we're installed about a year and a half ago...but I will definitely have a mechanic check it out. Thank you!
  4. Apr 23, 2023 at 5:30 AM
    memtaco
    Stephen
    At high speeds it doesn't take much uneven rotor wear to cause a vibration.
  5. Apr 23, 2023 at 5:49 AM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    Sounds like rotors to me.
    12TRDTacoma, Rocketball and wilcam47 like this.
  6. Apr 23, 2023 at 6:35 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I would assume you are in line for a new set of rotors and pads
    What you are describing sounds like a warped rotor
    wilcam47 likes this.
  7. Apr 23, 2023 at 6:35 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My guess is the rotors too.
  8. Apr 23, 2023 at 6:37 AM
    Oldewing1800
    Oldewing1800 Well-Known Member
    2006 Double Cab
    Dog hair, lost happy meal parts from Grandkids....
    If you are lightly braking when this happens, yep, rotors are in your future. Check tire pressures as well. Shocks really don't come into play here.
    12TRDTacoma, wilcam47 and Leomania like this.
  9. Apr 23, 2023 at 6:46 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    But if your shocks are original, then they likely need to be replaced in any case.
    12TRDTacoma and Alexely999 like this.
  10. Apr 23, 2023 at 7:09 AM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Had similar issue…replaced my rotors, problem remained…balancing my tires fixed it.
    Jensonbt likes this.
  11. Apr 23, 2023 at 7:16 AM
    Bishop84
    Bishop84 Well-Known Member
    Brake rotors have run out causing pulsation with heat.
    Worn steering and suspension components can make it feel more aggressive though.
    Sounds like you're due for an inspection.
    Make sure the drum brakes get adjusted regardless, it will help the truck stop without needing as much force on the fronts.
    12TRDTacoma likes this.
  12. Apr 23, 2023 at 7:19 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    Slowing down by pressing brake pedal? Or slowing down by letting off the accelerator pedal without touching the brake pedal?
    b_r_o and wilcam47 like this.
  13. Apr 23, 2023 at 10:26 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Everyone in here is saying brakes, but it could possibly be your Ujoints or center bearing. I have shakes decelerating (plus shakes and noises at lower rpms) and I just got confirmation from my shop yesterday that my center u joint is out.
    birry likes this.
  14. Apr 23, 2023 at 10:33 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm going to throw another one out here. If the brakes and rotors Are fairly newer, you may want to have them check the amount of rust that has developed on the rotor hats and have them scrub it off if there is a lot on it.
    After installing my all aluminum Bora spacers on the front of my rotors I haven't had an issue with brake rotor vibration for the last 8 years. I have used the same rotors every time and have changed the pads out twice, technically riding on 3 different sets of pads. Not something I preached in my professional career, but in my personal, oh yeah.. less work for me in the end.
    Not saying you should go out and buy spacers just for that reason alone, but what it has cured and abated (despite tons of rust build up existing on my hats from then to now is something to be aware of.
  15. Apr 23, 2023 at 3:44 PM
    Falcoholic87
    2005 Tacoma
  16. Apr 23, 2023 at 4:21 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Then it's brake related like everyone is saying. Replace or resurface the rotors
    And check for a tight caliper too
  17. Apr 23, 2023 at 5:34 PM
    birry
    Oklahoma City, OK
    2008 4x4 DCSB
    FYI - Last time I did this (a few years ago), there was little difference in cost between new rotors and resurfacing. I just went with new.
  18. Apr 23, 2023 at 6:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Oh I know, I work at a shop. I was just throwing options out
    birry[QUOTED] likes this.
