Steering wheel shakes when braking at high speed
Discussion in 'Arizona' started by Flynn Diesel, Oct 5, 2012.
  1. Oct 5, 2012 at 10:10 AM
    Flynn Diesel
    Flynn Diesel [OP] Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
    So my steering wheel has been shaking and getting progressively worse when slowing down at highway speeds. I recently had the truck in for regular service and asked them to take a look at it. I assumed it was a brake issue. They recommended brakes/rotors, an alignment and new tires because they are feathering. Obviously they didn’t make enough from my pre-paid service. I declined all and an seeking some opinions.
    2010 Pre-Runner
    285/70/17 BFG AT/KO
    5100’s @ 2.5 with stock UCA’s
    Rear TSB
    27,000 miles
  2. Oct 5, 2012 at 10:13 AM
    Aw9d
    Aw9d That one guy
    Rotors are warped or tires are out of balance.
    Take the tires to discount tire and have them check balance first. If that is ok and you still have an issue, check rotors next.
  3. Oct 5, 2012 at 10:49 AM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    From the sound of it you have a toe issue with your alignment causing the feathered tire. Also if the shake in the steering wheel is only during braking chances are you have warped rotors. Napa, Vatozone, and O'Reily can resurface them but you are trusting parts counter mechanics to do it. In my opinion, I would trust Napa before the others unless you know and trust someone that works there.
  4. Oct 5, 2012 at 10:50 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2.
  5. Oct 5, 2012 at 10:55 AM
    seric007
    seric007 Well-Known Member
    alignment caused my 285's to shake the wheel, alignment cured. but balance is your most likely culprit. if its the rotors you would feel it in the pedal (do you?)
  6. Oct 5, 2012 at 11:10 AM
    Flynn Diesel
    Phoenix, AZ
    Nothing in the pedal. Oddly enough though I tend to rest my hand on the shifter while driving and have noticed a vibration there. Could that be related?
    I'm having the tires rotated and balanced after work. Discount said they'll do if for free. If I don't notice a significant change I'm going in for brakes and alignment. The last thing I want to do is spend a grand on new tires but if I do I'm consideing going smaller and dropping my 5100's down to 1.75.
  7. Oct 5, 2012 at 11:12 AM
    Aw9d
    Aw9d That one guy
    Between alignment, breaks, and balance you'll get it fixed. Sounds like warped rotors to me.
    Good luck man!
  8. Oct 5, 2012 at 8:40 PM
    seric007
    warped rotors without pedal wobble? doubtful.
  9. Oct 6, 2012 at 9:35 PM
    05TacoRunner
    Peoria, Az
    Very possible. Our corolla does it after heavy use. I used to see it all the time when I worked for Cadillac.
  10. Oct 6, 2012 at 10:20 PM
    seric007
    that is a disturbing thought, poor material? Heats up...warps.. cools down.. unwarps? :confused:
  11. Oct 7, 2012 at 9:12 AM
    Flynn Diesel
    Phoenix, AZ
    Well I had the tires rotated and balanced. Did not fix the problem. I'm taking it in next weekend for brakes.
  12. Oct 7, 2012 at 2:16 PM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    18 Rapturd
    Flynn, can you post a picture of your front rotors? Take the wheel off and take a good picture of the rotor for me. I think I have an idea of what it is if it was not the tires or alignment.
    If you have blueing or scoring in your rotors then they may have heat spots. If you stop with your foot still on the brake from a highway stop or whatnot in the valley, you may put hot spots on your rotors. This hardens or glazes a part of your rotor which loses the friction rate which then does not stop and actually "skips" when you are braking. I had this problem on my wife's 4Runner's, 04, 06, 06, and 08. All 4WD V8 4runners and they had this problem. Sometimes there may not be much signs on the rotors.
    I would try bedding in your pads first. Being LEO, do it somewhere safe and where you can and don't pull me over if you see me doing it. Drive it up to 30mph, then progressively apply maximum pressure until you are about to completely stop then let go. Key. DO NOT stop completely! drive up to 60mph and do that same procedure by braking hard but not locking the wheels. If you are able to do this 3-4 times @ 60mph, rest your vehicle in neutral with foot off the brake. This will have bedded in your brakes and shaved off any left pad material on the rotors or pads off for a cleaner smoother surface.
    If that does not fix it, unfortunately you will have to replace your front rotors. I HIGHLY suggest as a replacement Powerslot slotted or DBA slotted rotors. Do not buy cross drilled.
    let me know your findings.
  13. Oct 7, 2012 at 2:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Regular high speed braking would kill most any rotor. [​IMG]
  14. Oct 7, 2012 at 4:49 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I never felt anything in the pedal with my warped rotors... I think the way the brakes are setup at least with my '10 a-trac setup is a bit diff than normal. Either way, it helped a lot replacing them, and I just used Vatozone Duralasts... they've actually been pretty legit thus far.
  15. Oct 7, 2012 at 5:01 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Holy hot spots batman. 100% its the rotors, a balance issue would happen all the time, not just when braking. Nowadays a warped rotor will be felt in the steering wheel, not always in the pedal. The last thing i would even consider is tire balance purely based off the OP's description.
  16. Oct 8, 2012 at 5:46 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Both of these are untrue. Balance issue tends to only happen during certain speed intervals unless they are really out of balance. Warped rotors will always be felt through the pedal even with the ABS block because a warped rotor will push fluid back through the caliper which will push back through the ABS then the master which is tied into your pedal.
    And no, techs do not make jack from a prepaid service. The upsell is where the gravy is at. But you cant be mad at them for that. Like every capitalistic company they need to make money to survive.
    Now the dealer gave you the three things to fix and you took the cheap route by having Discount only try and do one which is understandable money is tight right now. However, did they force match those larger tires? Also did they dynamic balance them? (placement of the weight on the wheel) Im thinking no since it was free but if they did tires can be ruled out. Your tires feathering are most likely from the alignment issue but without pics it is hard to say. AT KO's should be about ready to go with that many miles on them. As for brakes, 27k on those size tires and that weight of truck its about time for brakes and rotors. Take into acount the heat marks and I would surmize that your culprits are the alignements and brakes.
    As for your vibration issues within the shifter. You have large offroad tires on your truck. Your going to feel things more because of it. You want it to ride and feel like a mercedes, buy a mercedes. ;)
    Also a recommendation for your next tire choice. Goodyear Duratracs. A bit pricey for an AT but twice the life span of a BFG with better road wear and handling.
  17. Oct 8, 2012 at 5:58 PM
    Toyota Tech31
    Debary, Florida
    First, the Op stated that the issue is happening "When slowing down at highway speeds", this to me would indicate that he is braking, not that he is coasting or anything else. 2nd, I do agree that tire vibratins do tend to happen at distinct speeds depending on the individual vehicle, but again, he mentioned "when slowing down" so he would not have been going any particular speed in which to indicate tire vibration.
    Now regarding what you and a few others, including the shop, have stated, @ 27k miles why in the world would any vehicle need new rotors? If i were a gambling man i would be willing to bet this is the OP's first major brake issue thus indicating that his rotors have never been resurfaced and will have plenty of life remaining once they resurface them to rid the warp. He has not fully shown nor indicated any major hot spots and until he does, i say resurface along with a full front brake job and get an alignment to help with the feathering issue.
  18. Oct 8, 2012 at 5:59 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Alignment does NOT cause a vibration. Replace your front rotors! And pads d they're below 50%
  19. Oct 8, 2012 at 6:05 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Lies. Alignment most certainly can cause vibration especially on aggressive tread.
    Pads below 50% are perfectly fine... it's all about even wear.
  20. Oct 8, 2012 at 6:12 PM
    Spoonman
    Jamie
    Alberta
    I've never felt any alignment cause a vibration. And I've done thousands of alignments. And diagnosed and successfully fixed dozens of vibration issues. However...I do understand how aggressive tread could cause a very slight vibration. As for the pads, I like to replace pads and rotors at the same time if te pads are below 50%. Sure they're probably fine. But I have had problems with come backs due to squeeling. It's safer and easier(since you're already in there), to just do a full brake job. Some people believe in doing things differently. I like having the vehicle fixed in one shot with no come-backs.
