Steering wheel shakes when braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ddaughen15, Feb 14, 2019.
  1. Feb 14, 2019 at 3:07 PM
    Ddaughen15
    Ddaughen15 [OP] Well-Known Member
    Dylan
    New York
    15’ Tacoma SR5
    So I’ve had my truck for about a year now and it is sitting at about 38k miles, I bought the truck with 26k miles. When I am traveling the highway or any road for that matter at about 60+ Mph and start to brake my steering wheel and front of my truck shakes quite aggressively, not anything I can’t control but enough to cause concern, I have had 2 oil changes since I’ve owned the truck and when they give me the brake results they have graded them at 100% (I’m not sure if they put new brakes on before I bought the truck or if they are still the ones from factory) I ask the dealership to actually look at the rotors and brakes but they tell me everything is fine. Wondering if anyone else has had this problem, I’m thinking it can be fixed with a new set of rotors and pads but if anyone has any other ideas what it could be it’d be greatly appreciated! Thanks TW!
  2. Feb 14, 2019 at 3:09 PM
    DrFunker
    DrFunker Well-Known Member
    Mine used to do the same. New pads and rotors and it is super smooth once again.
    oni06, birry, 303tacoma and 1 other person like this.
  3. Feb 14, 2019 at 3:12 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    That’s where I would start
    With the rotors
  4. Feb 14, 2019 at 3:14 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I had the issue twice.. often becomes an issue after an emergency brake on already hot brakes, then sitting with the brakes applied. This causes the pad to 'imprint' into the rotor thus creating a raised surface which can be attributed to the pulsating feel while braking. It has been mentioned you can clean up the rotor with some fine grit sandpaper, however I opted to purchase the Powerstop K137 kit. Braking feel was significantly improved over stock.
    JGO, eccracer104 and Ddaughen15[OP] like this.
  5. Feb 14, 2019 at 3:15 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    When you brake hard you heat up the pads (obvious I know), but if you come to a stop with hot brakes and just hold your foot there, when you let off your brakes the pads transfer brake pad material onto the rotor. This creates that vibration feeling, residual pad buildup on the rotor surface.
    Pull your rotors and have them resurfaced, if your rotors and pads are in good shape this should be an easy $30 fix.
    To prevent this from happening again simply let the brakes drag for a foot or two so you're not keeping the pad and rotor on the same spot, this will aid in cooling more efficiently without pad transfer.
    Ddaughen15[OP] and dually like this.
  6. Feb 14, 2019 at 3:16 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Beat me to it by a minute :thumbsup:
    Ddaughen15[OP] likes this.
  7. Feb 14, 2019 at 3:17 PM
    dually
    dually Low and slow
    Us OG members have to represent!
  8. Feb 14, 2019 at 3:17 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    :cool: :fistbump:
  9. Feb 14, 2019 at 3:20 PM
    birry
    birry Well-Known Member
    Oklahoma City, OK
    2008 4x4 DCSB
    OME 885, Bilstein 5100's, Wheeler's (single) AAL
    I had a similar issue recently (but my truck had 155k). Replaced the rotors / pads, and all is smooth as can be now. Its fantastic. Cost me just under $250 to replace all of it myself.
    Also noticed that whoever did the brakes before put both of the metal warning strips on the passenger side instead of splitting them to each side :facepalm:
  10. Feb 14, 2019 at 8:08 PM
    LJrubi
    LJrubi Well-Known Member
    Dan
    North West NJ
    2015 MGM TRD Sport DCSB
    My truck does the same thing with 62k on the odometer. I'm going to just replace the rotors and pads when it warms up a bit.
  11. Aug 28, 2019 at 11:34 AM
    glockner
    glockner Well-Known Member
    Scottsdale, AZ
    2006 Tacoma TRD Sport 4x4
    So, reviving this thread, I just recently had my rotors resurfaced... yesterday I noticed this steering wheel shake when entering highway from on ramp (no brakes applied) and when taking exit off of highway (brakes applied). I have no shake when driving at slower speeds (<50mph). It was like 114 degrees yesterday here in Scottsdale and I did a little driving around. If brake pad material was transferred to my rotors, would I be able to see it? I went and looked at my rotors today and they looked pristine with nothing on the surface. I am going on a long road trip this weekend and want to make sure I am safe to drive.
  12. Aug 28, 2019 at 11:41 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    A long trip should help you, not hurt you.
    Roll On!
  13. Aug 28, 2019 at 12:38 PM
    glockner
    Scottsdale, AZ
    Guess so, hopefully it will just go away. If it persists I'll probably take back to brake shop that resurfaced my rotors and have them check it out.
