Steering Wheel Shakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kedin, Feb 8, 2016.
  1. Feb 8, 2016 at 5:32 AM
    kedin
    kedin [OP] New Member
    Steering wheel shakes when the brake is press while driving at 40mph and higher
  2. Feb 8, 2016 at 5:37 AM
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    Warped front brake rotors.
    Lord Helmet and ZachPrerunner like this.
  3. Feb 8, 2016 at 5:42 AM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    ^^ Most likely the case
  4. Feb 8, 2016 at 9:00 AM
    CVOTRDSPORT
    Forgot to mention warped rotors or drums the pedal will pulsate, if steering wheel shakes its more likely the front discs. This is with the presumption your wheels are not out of balance or if you had any suspension work done that everything is correct an tight. 40-45 mph is about the right speed for unbalanced tires to start to wobble. Check it again without using the brakes, if it does I doubt its the brakes.
  5. Feb 8, 2016 at 12:36 PM
    calico
    calico Well-Known Member
    Northeast
    13 Tacoma Limited
    Viper Alarm and Remote Start Prestigious Society mod Camera display relocated to headunit Weathertec floor mats, window deflectors, and mud flaps Toyota Bed mat Tailgate lock Undercover SE tonneau and Swing Cases (driver and passenger) Hi-lift install Fumoto Qwik Valve ImMrYo Mirror mod Salex console organizer
    I have had "the shakes" since I bought the truck new in 2013. I've had new tires, balance, and alignment and it still does it intermittently, as it always has.
  6. Feb 8, 2016 at 6:25 PM
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    While the brakes are applied? I've had this same issue since I bought the truck. But it's ever now and again. Both with stock and new wheels. Brought it to Toyota while it was still under warranty and they did a full brake job. When away for a bit but it's still there.
  7. Feb 8, 2016 at 6:34 PM
    CVOTRDSPORT
    Have you had your wheel bearings checked? They may be out of spec
  8. Feb 9, 2016 at 3:28 AM
    calico
    Northeast
    13 Tacoma Limited
    My apologies, I should have been clearer. No, my steering shakes intermittently just as I drive down the road. It just seems to come and go.
