Steering Wheel Shakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kowalski2k, May 19, 2019.
  1. May 19, 2019 at 8:09 PM
    Kowalski2k
    Kowalski2k [OP] New Member
    2013 Toyota Tacoma Texas Edition
    NA
    Hey Yall i have a 2013 Toyota Tacoma Texas Edition with roughly 53000 miles on it currently. Im having an issue with my steering wheel shaking between 55-70 Mph and ive already done an alignment as well as a tire balance. I cant seem to figure out exactly whats going on with it. If anyone has any ideas please let me know. Thank yall.
  2. May 19, 2019 at 8:12 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW!
    DrFunker likes this.
  3. May 19, 2019 at 8:32 PM
    yscty
    yscty Well-Known Member
    South Orange County, CA
    09 BLACK TRD SPORT DCLB
    NONE YET
    Are your tires cupping, this very well could be the cause...
  4. May 20, 2019 at 12:43 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Was anything done to the truck right before this started?
    If not a simple thing maybe:
    Tacoma really need a road force balance on the front tires that checks the heavy spots on the rim and tire and they can rotate the tire on the rim to offset. Also checks for a bad tire/ripped cords or just bad manufacture - yes even new tires can be so out of balance they should not be used. If you have a lot of balance weights on the tire that is a sign. If shop did several weights in different areas of the rim their balance was crap. Over the years had several bad balance experiences so now I always ask if shop has road force machine. Discount tires usually do and many dealers (but dealer can cost over $50.) A recent flat repair can also cause with a bad balance.
    This is first thing to do but many other possible causes - shocks, steering rack or damper in steering wheel, suspension, etc. Do not chase these really until you rule out the balance for real.
    jkuniverse likes this.
  5. May 20, 2019 at 3:58 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Broken belt will do that, but surely they'd have caught that during the balance process.
  6. May 20, 2019 at 5:00 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Balance or warped rotor - usually caused by those wonderful sticking calipers.
    Turdyota3000 likes this.
  7. May 20, 2019 at 7:18 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Alignment can do it.
    "In spec" doesn't always mean it's good.
  8. May 20, 2019 at 7:19 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Stock tires or oversized?
  9. May 20, 2019 at 7:21 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Rotate tires and see what happens
    That one old guy likes this.
  10. May 20, 2019 at 7:22 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    My front were cupping and causing vibration, rotated the tires and it stopped.
    yscty[QUOTED] likes this.
  11. May 20, 2019 at 9:08 AM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    I had a bad vibration at speeds of 45+. Turns out it was a bad steering rack. No more vibes.
  12. May 20, 2019 at 9:21 AM
    Clearwater Bill
    Billy
    Largo Florida
    Hmmmmm.
    How so?
    There you go again, starting simple and free. :thumbsup:
    hoverlover and b_r_o[QUOTED] like this.
  13. May 20, 2019 at 9:51 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I dont know the how behind it. Just know i've had steering wheel shake at speed on my 2nd gen that went away after adjusting toe slightly.
    b_r_o likes this.
  14. May 23, 2019 at 6:05 AM
    datenhoff123
    datenhoff123 Sasshole
    Kandace
    Iowa, louisiana
    2018 toyota tacoma sr5 4x4
    tinted windows, leveling kit, trd wheels, blacked out emblems, radio premium upgrade
    so since we are talking vibrationss! im about ready to throw this truck away! i have 12 tacoma BRAND NEW WHEELS and BRAND NEW STOCK RIMS because of this shaking and its still there! and when you hit a bump the wheel is darty and goes everywhere. dont even think of getting in a draft behind a 18 wheeler cause they truck is walking the road. HELP! lol im so over it. my fiance is a mechanic and checked the front end nothing is loose or seems to need to be changed. i work at a dealer ship and even got the guys there to look at it. the only thing they could find was a lil play in my swing bearing but they said it was not enough to make it shake as bad as it is.
  15. May 23, 2019 at 6:14 AM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    OP,
    If you rotate your tires, torque your lug nuts properly. I always ask the shop I go to, please don't use a impact to tighten lugs.
    Welcome Aboard :thumbsup:
    spitdog likes this.
  16. May 23, 2019 at 6:43 AM
    15TACOSPORT4X4
    15TACOSPORT4X4 Well-Known Member
    Stan
    2015 Black Tacoma TRD Sport 4x4
    3" lift on 33 inch Nitto's with 18" Fuel wheels. N-Fab step bars. Husky floor liners.
    I would get my alignment checked. It sounds like one wheel is out making it drive a little Squirrely
  17. May 23, 2019 at 6:59 AM
    datenhoff123
    Kandace
    Iowa, louisiana
    yeah that was my next objective lol. im going to get the guy here at work to see if the balance on them are off. if all good its going to the alignment shop!!!
  18. May 23, 2019 at 10:29 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    The "darty" usually means caster is out. Alignment should fix you up.
    wilcam47 and hoverlover like this.
  19. May 23, 2019 at 11:25 AM
    datenhoff123
    Kandace
    Iowa, louisiana
    HOPE SO CAUSE I DID NOT NEED NEW RIMS AND TIRES BUT THOUGHT MAYBE THAT WOULD FIX IT SO 1000 DOLLARS LATER!!!! DONT WANT TO GET IN TO DEEP ON THIS!
  20. May 23, 2019 at 11:30 AM
    15TACOSPORT4X4
    Stan
    Only a grand for wheels and tires. You did good. Mine was 2300. That hurt.
