Steering wheel Shakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD Fisher, Feb 22, 2021.
  1. Feb 22, 2021 at 2:51 PM
    TRD Fisher
    TRD Fisher [OP] Well-Known Member
    Abingdon, MD
    2014 TRD Sport
    I have been having severe front wheel shake under braking and it has been getting worse. Stock rotor with TRD pads. Love the combo but after a I had to lock them up at 70 or so the vibration has been getting worse.
    I am one that never turn rotors, but they are only about 6 months old. Worth finding a shop to turn them or just get new rotors. I thought I read someplace that the metal has a memory and it may come back after breaking.
    Keep OEM rotors or do something different.
    Or is there something else to look at that I may be missing?
  2. Feb 22, 2021 at 3:17 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Imo I’d turn them. Turned mine at 90 for vibration when i did brakes 20k later still good. Oe rotors.
  3. Feb 22, 2021 at 3:18 PM
    gotoman1969
    They need to be turned on the truck. Not on a bench lathe.
  4. Feb 22, 2021 at 3:21 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    The only issue with getting them turned is that it might be cheaper or the same price just to get new rotors.
  5. Feb 22, 2021 at 4:06 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Probably just brake pad residue. Go find an empty road where you can make repeated hard braking runs from 55 to 10 mph and see if that solves it before having the rotors turned.
  6. Feb 22, 2021 at 4:29 PM
    TRD Fisher
    Abingdon, MD
    2014 TRD Sport
    I’ll give it a shot- think they are beyond that but doesn’t hurt to try. Just need this ice to go away first.
  7. Jul 12, 2021 at 6:31 PM
    normb
    normb Member
    So Cal
    12 D/C TRD O/F
    Does it shake every time you brake now? Or, is it intermittent. I have the brake and shake problem, but it is not consistent. Sometimes it shakes whenever I brake. Sometimes it is fine. It is more common if the brakes are warm. If it were warped rotors,. wouldn't shake everytime I brake?
  8. Jul 12, 2021 at 6:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    Rotors don't warp. It's a hunk of cast iron. If you managed to get them hot enough to warp the brake fluid would have boiled and you'd have lots 'o problems.
    Try cleaning the rotor (both sides) with an aggressive scotchbrite pad and brakekleen to see if you can remove the pad material build up.
    Whether you need new pads or not, after cleaning follow a standard brake bedding procedure.
  9. Jul 12, 2021 at 8:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds the rotors have lost the ability to stay straight/true when they get hot. Probably time for new ones.
    If the problem was pad material build up, it would shake all the time hot or cold. Just that fact that the temp makes a difference in shaking means that it's not brake pad material. Brake pad material isn't temperature sensitive, but metal can be.
