steering wheel shaking after lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dnobz28, Feb 27, 2018.
  1. Feb 27, 2018 at 4:50 PM
    dnobz28
    dnobz28 [OP] Member
    I put a 3 in lift in the front and 2in lift in the rear. Put the diff drop in the front by the skid plate. Whole truck shakes and steering wheel shakes around 30 mph. Got tires balanced after. Now it shakes around 45 to 60. Saw some vids on dropping the carrier bearing a qtr inch as i did. Seemed to help the rear but steering wheel still shakes back and fourth. Any suggestions on my 2013 taco thanks
  2. Feb 27, 2018 at 6:26 PM
    Pigpen
    Dan
    Northwest Montana
    The shaking is because the wheels aren't seated properly on the hub. Loosen the lugs and tighten them to spec by hand, not with an impact wrench. Your steering wheel will stop shaking. I have to do this every time I go to the tire shop.
  3. Feb 27, 2018 at 7:20 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    At Discount Tire, I tell them hand tools only, and no longer have a problem. Maybe an option for you?
  4. Feb 27, 2018 at 7:29 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    If its not your lug nuts... You most likely need aftermarket UCA's. Your alignment is probly maxed out caused by your lift.
  5. Feb 27, 2018 at 7:31 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    UNLIKE
  6. Feb 27, 2018 at 7:32 PM
    Comatose
    Miguel
    San Diego, CA
    Shhhhh
  7. Feb 27, 2018 at 7:45 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Remove the front diff drop
  8. Feb 27, 2018 at 8:25 PM
    Pigpen
    Dan
    Northwest Montana
    I get a discount at the tire shop and they're really good to me. I don't mind taking ten minutes to take care of it when I get home.
