steering wheel shaking!!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ozmon420, Dec 19, 2008.
  1. Dec 19, 2008 at 9:04 AM
    ozmon420
    ozmon420 [OP] Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    just put on my new wheels 285/60-18's and now my steering wheel shakes a bit what can it be?
  2. Dec 19, 2008 at 9:12 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Maybe your tires were not balanced right? I would go back and have them rebalanced.
  3. Dec 19, 2008 at 9:18 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ^^^^+1.............get them rebalanced, and make sure they torque the wheels to the correct specs, maybe 85ft.lbs., tell them dont tighten the crap outta them with an impact gun.
  4. Dec 19, 2008 at 9:19 AM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    +1
    definitely check the balance, and do it soon before it wears on something.
  5. Dec 19, 2008 at 11:41 AM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    3 Words: Road Force Balance
    Step 1:
    Use this Tool to locate a Hunter 9700 in your area:
    http://www.gsp9700.com/pub/search/findgsp9700.cfm
    Step 2:
    Make calls and find a local shop. Confirm they have the Lug Centric Adaptor.
    Step 3:
    Make an appointment. It is the best balance to be had, worth every cent.
    Step 4:
    Make sure your alignment is as close to spec as possible assuming you lifted your truck to fit 285's.
  6. Dec 19, 2008 at 2:12 PM
    ozmon420
    miami, florida
    08 tacoma
    havent lifted the truck yet should be getting coilovers next week . took it on the highway dove about fifty miles at 70mph and it was fine , but when i drive locally it shakes not bad but enough to bother me. will i damage anything if i continue to drive for at least another week?
  7. Dec 19, 2008 at 2:15 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    X2!
    New off the lot mine was rebalanced twice and didn't help. The dealer finally did the road force balance and found 3 bad tires!
  8. Dec 19, 2008 at 8:19 PM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    Hey just to confirm, you said wheels when Im sure you meant tires only because you mentioned a size. Besides balancing, if you did get wheels, then maybe they're "Out of Round" or even the tires for that matter. More than likely, Balancing. You should notice it more when you brake. At least that has been my experience. Hope this helps. Later.
  9. Dec 20, 2008 at 5:08 AM
    SnoBoarder
    Lost
    ^Good point. The cool thing about the 9700 is that it can detect high and low spots on the wheels and tires and instruct the technician to break the bead and rotate the tires a specific amount on the wheel to counteract various imperfections in both, allowing the best possible balance.
