Steering wheel Shaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wilempire, Oct 17, 2016.
  1. Oct 19, 2016 at 9:42 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I also highly suspect that your factory Bilstein shocks may be worn out. How old are they? If they are 5 years old, or older, they're toast and will amplify any issues you have with suspension, balancing, etc. Something to consider getting taken care of, and probably a good opportunity to upgrade to a beefier shock.
  2. Oct 19, 2016 at 9:50 AM
    B ill y
    B ill y Well-Known Member
    Billy
    Sarasota County, Florida
    2018 4Runner Trd OR, 1997 FZJ80,1985 FJ60
    well its to late. i just bought control arms. at least i think i did the don't make them any more for my truck . thats what total chaos said. and i found 2 sets so i bought one set in a panic thinking i was screwed at getting some. and now this. ya it was tire king dam that did balance they were bitching about my tires eating up there weights. they were new bfg ko2 from tire rack. 31x10.5x15 not that big. the rims were japan not china. so should i take it to a different shop and get a new balance .
  3. Oct 19, 2016 at 9:58 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    I had a similar problem, no matter how many times the wheels were balanced. Finally I found a tire shop (Discount Tire) in NC near Charlotte, they use the Haweka adapter when balancing. Night and day difference. I am needing tires soon, I will have to find a shop out here in California that uses the adapter.
    It is the tire balance. For some reason, regular balancing on some trucks don't cut it. Haweka FTW...
  4. Oct 19, 2016 at 10:04 AM
    B ill y
    Billy
    so ask if they haweka balance . and they will say yes we can or wtf did you say.
    Kyitty likes this.
  5. Oct 19, 2016 at 10:12 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    There's tire/wheel balancing... and there's "Road Force Balancing". Makes a difference. TW is full of threads about poorly balanced wheels on Tacoma's causing wheel shake.
  6. Oct 19, 2016 at 10:18 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    Yup, pretty much what you said...
  7. Oct 19, 2016 at 10:19 AM
    B ill y
    Billy
    when i was in there they said if i put the weights on rim face. the hammer on kind. that it would balance better. is that Road force balance . cause all my weight is tape weight in the center of rim on inside.
  8. Oct 19, 2016 at 10:24 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    You can use the tape weights, I do because I hate what the pound on weights do to the outside of the rim. Since Toyota truck wheels have a huge backset, putting the tape weights as close as possible to the outside edge of the inside of the rim, it works perfectly. I don't care about the inside rim edge, so I have them use the pound on weights there. Works just fine and dandy..
  9. Oct 19, 2016 at 11:04 AM
    MattFL
    MattFL Well-Known Member
    S. Florida
    1999 Tacoma V6 4x4 TRD Extended cab
    A good balance may require weights both inside and outside. I took my truck to Sears in the past and they had an adapter for the tire balancer with "Tacoma" stamped on it. The guy used it, but my balance wasn't good. The next shop I tried did not have an adapter for their machine, but they did have a road force machine and that made all the difference in the world. So some machines require and adapter, and others don't apparently. My tires are 31 x 10.5 R15. Also I noticed a big improvement switching to Michelin tires. In the past I also used Goodyear and Yokohama, and the Michelin just seemed to be rounder and ride smoother for lack of a better description.
  10. Oct 19, 2016 at 11:08 AM
    MattFL
    S. Florida
    No, road force is where the machine puts a load on the wheel while it is spinning, to simulate the weight of your truck on the wheel while it is spinning.
  11. Oct 19, 2016 at 11:46 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    This is what Road Force Balancing is:
  12. Oct 19, 2016 at 12:51 PM
    B ill y
    Billy
    Cool. Thanks for info people.
  13. Oct 30, 2016 at 10:58 AM
    Train
    Train Loco with a motive
    Train
    N46°24'54" W81°01'48"
    2013 -Tacoma access cab 4x4
    Chop chop chop weld
    Balancing beads work good or air soft pellets
  14. Oct 30, 2016 at 2:46 PM
    B ill y
    Billy
    I changed my centric rings. Got aluminum ones had old broke and cracked plastic ones they were 2yrs old and it helped . Little bit less almost not an issue anymore.
  15. Nov 7, 2016 at 5:35 PM
    #35
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I have had the same issue with tire balance. I bought my Tacoma with stock TRD OFF ROAD wheels. No issues. Had Michelin ' s put on smooth as glass . Then I got that wild hair to get after market wheels and I had Hankook A T in 265 /70/ 16. Put on them and that's when it began . Vibration and wheel shake at 53 mph and at 60 to 70 mph. Had them balanced and rebalanced . Also had them road force balance done with no luck . Went back to my stockers with Michaline ' s and smooth as glass. Now I am get that wild hair again . Only I want to reuse my Michaline on the new wheels and get the road force balance done. Question is am I going to have the same issues? Freaks me out to think of going throw that again ! Any advice?
  16. Nov 7, 2016 at 6:00 PM
    #36
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    Find a shop with the Haweka adapter, all the difference in the world when it comes to balancing 6 lug Tacoma wheels..
