Steering wheel shaking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WrecKedByPotaTo, Mar 16, 2024.
  1. Mar 16, 2024 at 5:45 AM
    WrecKedByPotaTo
    WrecKedByPotaTo [OP] Member
    Travis Threeton
    08 red Tacoma
    I just got my tires balanced because the whole truck was vibrating when I was going 75 mph. Now the rest of the truck feels smooth, other than the steering wheel is shaking harder than before. Could it be as simple as I need to rotate my tires? It's been 2 oil change since they've been rotated. Or is my front end warn out? There is only 160k miles on the truck.
  2. Mar 16, 2024 at 6:12 AM
    Burritopa
    Burritopa Well-Known Member
    Sean
    NSB, FL
    '15 PreRunner 4 door 4 banger 5 bed
    What kinda wheels? They match the hub bore or have an adapter? Spacers?
    They could just be tires out of round (I've got one wildpeak that is)
    Just feel in the steering wheel only or your seat?
    Could be alot of things. If its not the wheels themselves and its only in the steering wheel, could be tie rods
    wilcam47 likes this.
  3. Mar 16, 2024 at 6:20 AM
    WrecKedByPotaTo
    Travis Threeton
    08 red Tacoma
    They are 275/70r17 bfgoodrich ko2 on AE Alloy wheels. There is no adapters or spacers.
    It is only on my steering wheel. It starts around 45-55 and goes away when I go faster.
  4. May 29, 2024 at 1:26 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    OP, We’re you able to figure out what the cause of your steering wheel shake was?
  5. May 29, 2024 at 2:49 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    1) Sounds like either an improperly balanced wheel
    2) Bent rim
    3) Maybe improper inflation
    4) worn out tie rod ends.
    Recommend check in order of 3, 1, 2, 4
    Clearly I'm not much of a lineal thinker.
    IA DIY and Jimmyh like this.
  6. May 29, 2024 at 7:13 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    My truck had a bad vibration on the highway and I did the ECGS bushing install and it appears to have cured it. The needle bearing was coming apart when I pulled it out and looked at it on the bench. I do have a 1.5" lift though.
  7. Jun 10, 2024 at 3:40 PM
    IA DIY
    IA DIY Well-Known Member
    Iowa
    2008 DCLB 4x4
    Unlikely culprit, but worn sway bar bushings. They’re really easy to check.
  8. Jun 10, 2024 at 10:29 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you have four wheel drive, go through same speeds in four wheel drive mode. If vibration mostly disappears, the needle bearing is likely worn out. You can get a new needle bearing (about $40), or replace with the ecgs bushing (about $70). Note, you don't want to drive in four wheel drive mode in hard dry surface unless you gonin straight line. Find a hard pack gravel rode if you can.
