Steering wheel shimmy after getting new tires
Discussion in 'Wheels & Tires' started by 2004TacomaSR5, Jan 24, 2012.
  1. Jan 24, 2012 at 5:20 PM
    2004TacomaSR5
    2004TacomaSR5 [OP] Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    http://www.goodyear.com/en-US/tires/wrangler-silentarmor
    Just replaced the crappy Dunlops with these, love the tires, they grip really nice in snow and ice and behave well on the raod, BUT...I have noticed that the steering wheel has seemed to develop a shimmy at highway speeds. Its not really bad at all, and does not cause any handling problems, just really annoying sometimes is all, would anyone know if the tires are causing this? They are the same size and configuration as the Dunlops were.
  2. Jan 24, 2012 at 5:23 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Might have lost a weight or they may just need to be re-balanced. Swap the front to back and see if it goes away.
  3. Jan 24, 2012 at 5:24 PM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Sounds like a tire balance issue. Take them back to the shop and have them rebalance them.
  4. Jan 24, 2012 at 5:34 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Sounds like a balance issue or you have a bad tire. My truck did the same thing from 55-65 before I got new tires. Now it's gone.
  5. Jan 24, 2012 at 5:35 PM
    2004TacomaSR5
    Jon
    Montana
    Okay, I will do that, thanks for the input!
  6. May 23, 2012 at 7:43 AM
    Elkoholik
    Elkoholik ELKOHOLIK
    Buddy
    Bumpass, Va
    2011 Tacoma double cab long bed
    i recently purchased a 2011 tacoma double cab, with a long bed. 4 x 4. Dunlop tires, been in shop 6 times with wheel shimmy. dealer checked allignment, rebalanced tires numerous times. No fix yet. Steering wheel shakes 60 -72 mph. passenger looks like a its going to shake off. anyone else with this problem????????????
  7. May 23, 2012 at 7:53 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Have you tried road force balancing them?
  8. May 23, 2012 at 7:59 AM
    Bz3r0
    Bz3r0 Smackalicious!
    Bryan
    Edwards AFB, CA
    White 2017 TRD Offroad
    Under Construction
    Just from 60-72 MPH? Have you had the dealer check your front axle/drive is bent? Is it more of a vibration or noticeable wheel shimmy, and have you had a friend drive beside you to see if your wheel wobbles?
    Good luck in finding the cause of your problem.
  9. May 23, 2012 at 7:59 AM
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    After I replaced my stock dunlops on my 2006 with bfg at's I had the same steering wheel shimmy/shake at highway speeds. Had it aligned and balanced twice but it didn't fix it. Finally I got new wheels to replace the stocks wheels and the steering wheel shake stopped after that, one of the stock wheels was slightly bent and that was the thing that was causing it. That might not be whats causing your steering wheels shake but just letting you know my experience.
  10. May 23, 2012 at 8:00 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Had the same problem when I first got my Duratracs. Took it back to Discount, they remounted balanced every tire/wheel and the problem was fixed.
