Steering Wheel Shimmy
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SuperTacoma, Mar 1, 2011.
  1. Mar 1, 2011 at 6:09 AM
    SuperTacoma
    SuperTacoma [OP] Well-Known Member
    Clint
    Tennessee
    11 Toyota Prerunner TRD PKG
    Factory Mods Ventshades Bug Deflector Magnaflow Muffler Solid Fold Extang Cover Pop Lock Helix Power Tower Westin Brush Guard Westin Nerf Bars color match Scoop Hood
    Ok I search and read just about everything on Steering Wheel Flutter, Shimmy, Shaking.
    Here is what I found:
    1) Most were older model Tacos
    2) Some where modified (Maybe Death Wobble)
    3) Most were 4x4 and after they had been lifted or after new tires
    Mine is a 2011 PreRunner TRD 2WD. It has done it day one and it does not do it all the time. The steering wheel vibrates pretty hard sometimes. But this morning it was very smooth. It doesn't pull one way or the other.
    It is almost like when you ride an ATV and you are really moving 35 or better and it almost feels like the front end is going to come off the ground.
    I have read about some Steering Wheel rattle and a TSB for it but mine does not rattle.
    Anyone else have this issue?
    Thanks
  2. Mar 1, 2011 at 6:23 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    Go to the dealer ASAP , let em know. As new as it is might be anything from tire balance,loose part, or poor alignment.
  3. Mar 1, 2011 at 8:36 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Have you rotated the tires? If yes, did it change the vibration any? You might just need a good balance. Find somewhere that can do a road force balance (road force balancing machines find high spots in the tires, and can recommend the best placement for the tire on the rim to minimize vibrations) and make sure they use the adapter that uses the lug nut holes to mount to the balancer.
  4. Mar 1, 2011 at 10:01 AM
    gfisher99
    gfisher99 Active Member
    Austin, TX
    11 MGM TRD Sport DC
    Does yours do this when you are coming to a stop or cruising between 10-25MPH? Mine has a vibration anytime I am between 10-25MPH, whether I am cruising, like in a neighborhood, or coming down from, say 50MPH. I starts right at 25MPH and doesnt stop until I get to around 10MPH.
    I have a 2011 TRD Sport DC 2WD with about 1500 miles. Has done this since day 1. Just dont have time to be without my truck at the moment to take it it the dealer.
    Let me know.
    Greg
  5. Mar 1, 2011 at 10:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You're both under warrantee.... take it to the dealer.
    And honestly....even if you know exactly what the problem is...make the dealer fix it!! YOu paid a lot of money for that truck...get the most out of it and make them fix it.
  6. Mar 1, 2011 at 12:05 PM
    SuperTacoma
    Clint
    Tennessee
    Unless something major seems to be wrong I am going to have them look at it during my next oil change.
    I feel it most on the hwy and I usually drive around 70 mph.
    I have new wheels and the tires have been rotated at least once and it still does it.
  7. Mar 1, 2011 at 12:11 PM
    nick
    nick MURDERED_TACO
    Green mountain ,nc
    - 2003 trd
    your wheels has probally threw one of the weights off and now there unbalenced. mine did the same thing.
  8. Mar 2, 2011 at 9:17 AM
    gfisher99
    Austin, TX
    11 MGM TRD Sport DC
    Yep, I will but I was hoping to find out if the issue I have is something someone else has. I work 60+ hours a week and the nearest dealer is 40 miles away. My wife works just about as much so its hard to get picked up from and taken to the dealer before and after service.
    I am thinking this will be a multi-day repair and being without transportation is tough. Wish I wouldnt have sold my motorcycle :)
    Greg
  9. Mar 23, 2011 at 6:32 AM
    SuperTacoma
    Clint
    Tennessee
    Now I have a wheel shaking (almost like a Death Wobble) at higher speeds 60 - 70 mph but I also have where the wheel just rocks a little back and forth.I am going straight and it is riding smooth but the wheel just turns a little left then right. Like being behind an 18 wheeler on a windy day but only the steering wheel moves and not the truck.
    I am due for a an oil change soon so I am going to have them give it a once over.
    But if any others have this let me know.
    PS. Mine is 2wd.
  10. Mar 23, 2011 at 6:36 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    ^^^^ This, i've had it happen on a few of my vehicles, I frequent high speeds and it'll throw a weight off. OR you might have an excessive mud build up in the rims??
  11. Mar 23, 2011 at 7:59 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
  12. Mar 23, 2011 at 11:31 AM
    Bama_TACO
    Winfield, AL
    I'm quoting myself here....get a Road Force balance done.
  13. Mar 23, 2011 at 11:49 AM
    1bad10tacoma
    1bad10tacoma Well-Known Member
    Mark
    Brewer Maine
    2016 DCLB Sport
    tonneau,tailgate lock, OEM cruise, Int. wiper, , mud flap mod,weatertech's,fj rims
    I had this problem too, but it went away after i had the leaf spring TSB done.
