Steering wheel shimmy
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04truckman, Sep 20, 2017.
  1. Sep 20, 2017 at 3:56 PM
    04truckman
    04truckman [OP] Member
    2004 3.4L 4 doors 2wd
    none
    2004 2wd Tacoma. Odometer has 133700. on it.
    Have a shimmy in the steering wheel/column that occurs intermittently in the 35-60mph range. Not present at typical interstate speeds or 70mph or so. It seems to be coming from the left front. That is if I can really tell that it is coming from the left front from just driving the car? STEERING SEEMS TO BE CRISP AND RESPONSIVE. ALIGNMENT SEEMS TO BE GOOD. Toyota mechanic said that A arm bushings need to be replaced on all Tacomas with over 100,000. This has not been done.
  2. Sep 20, 2017 at 4:29 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Could be bad tie rod ends (inner OR outer).
    You can rule that out by jacking up one corner (with tire off the ground)
    and grabbing the tire at 9 and 3 oclock, and see if there is any play (should not be any).
  3. Sep 21, 2017 at 8:13 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    You should have your front wheels/tires balanced. An out-of-balance condition can cause the symptoms you describe, especially at 40-50 mph.
  4. Sep 21, 2017 at 8:49 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    But remember that the same symptoms you just described can be caused by a loose rack and pinion guide. Mine was sloppy as hell and replacing the roller style guide with the updated unit made a huge difference. And it was eeeeaaaasy!
  5. Sep 21, 2017 at 4:56 PM
    Glamisman
    Glamisman Well-Known Member
    I second the rack guide upgrade.
