steering wheel slack
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jonboy1, May 21, 2014.
  1. May 21, 2014 at 3:49 PM
    Jonboy1
    Jonboy1 [OP] Well-Known Member
    Jonathan
    Saraland Al.
    99 4X4 V6
    I have just replaced all of the ball joints and all inner and outer tie rod ends and I still have a little bit of slack in the steering. The truck has 200,000 miles so it is to be expected. So all of the slack is in the rack. I was wondering if there is any way to adust that like you can adjust the gearbox on trucks with no rack and pinion steering. Thinking about how they work, it makes since that thier wouldent be but I figured it couldent hert to ask.
  2. May 21, 2014 at 3:58 PM
    grublin
    grublin Well-Known Member
    TC
    Plano, Tx
    I don't think there's any adjustment in racks. I think the only thing left to check would be your steering shafts from the column to the rack.
  3. May 21, 2014 at 4:00 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Might help: Post 42 goes into a simpler way with less disassembly.
  4. May 21, 2014 at 4:04 PM
    grublin
    TC
    Plano, Tx
    Holy crap that's an insane write up!
  5. May 21, 2014 at 4:06 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    The author was pretty meticulous.
    It's a lot easier than it looks if you use the second method (post 42). 1-2 hour job total.
  6. May 21, 2014 at 4:06 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Yup ^ that fixed my issue I was having.
  7. May 21, 2014 at 4:46 PM
    Jonboy1
    Jonathan
    Saraland Al.
    99 4X4 V6
    Thanks jberry, Im at work now but I will look into it as soon as I get home in the morning. That looks to be what im dealing with.
  8. May 21, 2014 at 6:54 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    If you have the original 99 rack there is a good chance you have the old style "rack guide". Upgrading to the new style will remove "up and down" play found, and most pronounced at the driver side of the rack shaft.
    More info on that (and the rest of the rack) can be found here.
    http://www.tacomaworld.com/forum/1s...rack-pinion-service-tools-tips-dry-wordy.html
    Less than that if you know what you are doing. As the author of "post 42" I highly recommend following up with shimming the "tilt steering pivot ball" if the desired end result is totally smooth, fluid and slop free steering. It takes all of an additional ten minutes.
  9. May 22, 2014 at 2:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  10. May 22, 2014 at 12:48 PM
    VintageFast
    VintageFast Well-Known Member
    Jim
    DFW, Texas
    02 Prerunner 3.4
    I did the steering mod Tuesday night. Took about 2 hours. 1 bolt at the floor on the lower part of the shaft. 2 allen bolts at the wheel, 2 tilt springs, onplug the wiring and the column falls into your lap. The only thing I didn't like at first was it made my steering tighter. But, as I thought about it, the steering now seems like it did when I bought the truck new.
    edit... you have to take the cowling off to bet to the 2 allen bolts so add 3 phillips screws to the hardware to remove the column.
  11. May 22, 2014 at 2:45 PM
    Jonboy1
    Jonathan
    Saraland Al.
    99 4X4 V6
    I checked it out this morning and I definitely have slack there, I think the pivot ball also has some so I will be doing the mod there as well. Thanks for the tips guys this should be an easy fix and improve the steering by a ton.
  12. May 23, 2014 at 2:09 PM
    Jonboy1
    Jonathan
    Saraland Al.
    99 4X4 V6
    I done some more poking around last night and it appears to have a lot of slack around the rack as well. When you turn the wheel the whole end of the rack seems to bow up. When I started doing this project I looked for the rack bushings I have been reading about on this site but couldent find them. With the post that dirty pool listed Im wondering if I should just buy a new rack all together because I don't have access to the tools necessary to upgrade to the new style rack guide. And by the time I pay for it to be done and replace the bushings, Im sure I could just replace the whole thing. Am I off base here?
    Its weird, I swear I looked for the bushing but now when I priced the rack, I go strait to them LOL
