Steering Wheel Slight Off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ten Eight Rider, Mar 3, 2020.
  1. Mar 3, 2020 at 1:40 PM
    Ten Eight Rider
    Ten Eight Rider [OP] Well-Known Member
    Central California
    2006 White Tacoma SR5 DCLB 4x4 V6
    Fox 2.5" Coilovers, Fox 2.0 Rear Remote Reservoir DSC, SPC Light Racing UCA, Wheelers Progressive 1.5" AAL, Wheelers Bump Stops, Wheelers Braided Brake Lines, Fuel Revolver 16x8, Toyo AT 265/75/16, ECGS Bushing, Energy Suspension Steering rack bushings/sway bar bushings, All-Pro Sway Bar Links, At the Helm Fabrication bumpers (front and rear), Cali-Raised LED lights, Leer Cap
    Just had my truck aligned after installing new (OEM) steering rack and tie rods along with poly bushings. Have had my truck in for alignment twice and the steering wheel is still slight off about an 1/4"-1/2" to the right. Why is the shop having trouble getting my steering wheel lined up. Before I replaced the steering rack another shop had the same issue. Is anyone else having this problem?
  2. Mar 3, 2020 at 2:20 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Because they obviously don't know what they are doing.
    Why are you replacing the steering rack on a practically new Tacoma ( 2016 )?
  3. Mar 3, 2020 at 3:22 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Is the steering wheel off or is the alignment just so bad to drive straight you have to keep it 1/4-1/2" to the right? I had a somewhat similar problem recently (doesn't sound quite as bad) and they re-adjusted the caster and now its good to go.
  4. Mar 3, 2020 at 3:25 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    has 3rd gen, posts in 2nd gen forum to get actual results....
    OP, alignment shops are not typically nearly as critical as the actual user. You can adjust the steering wheel pretty easy by yourself if you have the couple of wrenches and a lil know how. Simply run one tie rod in a half turn and the other out a half turn, this wont change toe but will move the steering wheel.
  5. Mar 3, 2020 at 3:39 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
  6. Mar 4, 2020 at 10:08 AM
    Ten Eight Rider
    Central California
    My truck is 2006 with 145,000 miles, not sure why it is showing 2016.
  7. Mar 4, 2020 at 10:09 AM
    Ten Eight Rider
    Central California
    I believe the steering wheel is just a tad off. The truck appears to drive straight with no other issues than the steering wheel is off to the right 1/4" - 1/2".
  8. Mar 4, 2020 at 10:17 AM
    Ten Eight Rider
    Central California
    Last night, I noticed the steering wheel was off about a 1/4" the opposite direction, just like you described in your post. I'll try to tighten the Rack bolts as I have the Energy Suspension poly bushings like you and see if that helps. The rack I installed was brand new OEM so I don't think there should be any problems with it.
  9. Mar 4, 2020 at 3:53 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    That'll be your issue for sure. Easy fix, just try to get the wheel center before you tighten the rack bolts to save another trip to the alignment shop.
