Steering wheel stereo controls not illuminated?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vando, Sep 1, 2011.
  1. Sep 1, 2011 at 11:53 PM
    Vando
    Vando [OP] New Member
    Calgary AB
    06 Tacoma SR5 4x4
    The lights on my stereo controls are not working anymore, sometimes when I turned the wheel enough to the left they would work briefly but recently nothing. Is it a fuse or wiring or a bulb?
  2. Sep 2, 2011 at 12:06 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Sounds like a loose connection.
  3. Sep 2, 2011 at 12:08 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    [x] wiring
  4. Sep 3, 2011 at 4:28 AM
    Vando
    Calgary AB
    06 Tacoma SR5 4x4
    How difficult is it for me to get at and check the wiring? How do I do it?
  5. Feb 7, 2014 at 10:55 PM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    same problem
  6. Feb 9, 2014 at 8:49 AM
    SCOTTRODS
    SCOTTRODS JAFO
    Scott
    Garland, TX
    2014 Super White
    If you could, at one time, turn the steering wheel and get it to light up, then the "Clock Spring" is probably no good... it's fairly old for something that gets wound up and loosed all the time... I've heard it called many things, Clock Spring, Coil Harness, etc... whatever you or toyata calls it, it's nothing but coiled up flexible printed circuit... probably gone bad at one end or the other. Virtually un-repairable most times, but I have seen some actually repaired by a hard core electronics guy... A new one would be my suggestion.
  7. Feb 10, 2014 at 4:47 PM
    tbird95
    just pick up a new set of controls from a wrecker/auto recycler
