Steering wheel swap from older yota non airbag wheel???
Discussion in '1st Gen. Tacomas (1995-2004)' started by DIRT YOTA, Sep 11, 2015.
  1. Sep 11, 2015 at 7:30 AM
    DIRT YOTA
    DIRT YOTA [OP] Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    so I remember seeing a list of Toyota steering wheels from supra, celica and others that will directly fit a 1st gen Tacoma. I'm looking to swap in an older one with no airbag. Can't seem to find a list or thread about this. Anyone have a link to this or any info. Think it wa on ttora or customtacos but can't find it
  2. Sep 11, 2015 at 8:34 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    not sure if the ECM needs to "read" a good airbag to let it run or not, pretty sure airbags disable your ignition so not having one may act the same way
  3. Sep 11, 2015 at 8:58 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    My clock spring is broke and airbag light has been on for a while. Also unplugged the airbag sensors too. Don't think that's a problem. Seen a few 1st gens that swap supra wheels without airbags. Just can't find the thread.
  4. Sep 12, 2015 at 2:55 PM
    Wulf
    rock raisin
    IIRC it will run but the airbag light will stay on...either way you can wire in a resistor to work around it if you're running a non airbag wheel
  5. Sep 12, 2015 at 10:32 PM
    DIRT YOTA
    Cory
    Camarillo, CA
    Pulled airbag bulb long ago lol. Found several that should work
